too much oil in for...
[Closed] too much oil in fork lowers?
[#1041793]
Just done an oil change in my revs - 15ml in each leg. Also soaked the sponge wipers with oil. If i put too much in (5-10ml) what would happen? pop the seals?
Posted : 15/11/2009 5:43 pm
Would reduce the travel i would think
Posted : 15/11/2009 5:58 pm
If you were to put so much oil in that you half the amount of void space in the lowers, you would double the air pressure behind the seals and perhaps pop them out. A few ml is a small fraction of the void (I'm avoiding calling it air space to avoid confusion with an air spring, eben though that's how it will act) will make little difference.
It's a bit like worrying about shock pressures when you take your bike on a plane. The theory is there but actually, the chance is small and it doesn't really amount to anything.
I assume we're talking about the sloshing about near the bushes oil and not what's used for the damping circuit by the way, you did say in the lowers.
Posted : 15/11/2009 6:01 pm
correct - its the lube oil for the bushings and seals
Posted : 15/11/2009 6:27 pm
then a few ml extra isn't going to hurt.
Posted : 15/11/2009 6:28 pm
It wont pop them out.
