To drill or not to ...
[Closed] To drill or not to drill ?
[#2031001]
Got myself some xt wheels ,which can run tubeless and normal setup.
My question is if i drill them out for schrader valve fitting will i then wreck the chances of ever running tubeless in the future ie. if i sell them or just fancy a try on tubeless ?
Posted : 27/09/2010 11:36 am
why not just run presta valves?
Posted : 27/09/2010 11:38 am
xt wheels for your tractor? cool. 8)
Posted : 27/09/2010 11:39 am
I have a had alot of bad luck with presta !
like being stuck in the middle of nowhere and bending the valve bit you unscrew ?
anytips on not bending or snapping the valves ?
Posted : 27/09/2010 11:42 am
Bend them back and take a spare tube.
Posted : 27/09/2010 11:44 am
I tend to find it is press-on mini pump heads that bend the valves. I've not had any trouble since I switched to one of those Lezyne pumps that has a little piece of hose to connect to the valve
Posted : 27/09/2010 11:45 am
on bending back they snap !
you can't go wrong with the old style car valve.
Posted : 27/09/2010 11:47 am
If you drill a bigger hole you WON'T be able to go to tubeless.
my mate says they break. I bent one once because i was rushing and hamfisted. normally fine though. what are you doing to them? rubbish pump maybe?
Posted : 27/09/2010 11:48 am
Shortcut thats what i was thinking but look ...[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=46838 ]linky[/url]
Posted : 27/09/2010 11:49 am
Replacement valves are no more than a fiver so you could always carry one. It would be a real shame to wreck the tubeless versitility of the wheels because they are really very good.
Posted : 27/09/2010 12:38 pm
Presta are fine. Just don't use the valve itself as leverage when you snap on the pump- use both hands to counter the weight and you'll be fine
Posted : 27/09/2010 1:19 pm
if you get the replaceable core presta valves it shouldn;t be a major problem if you snap the odd one?
Posted : 27/09/2010 1:24 pm
 Gnnr
I use a presta to schrader converter as a valve cap on one of my wheels. This means you can use a forecourt air hose if in town.
Out on the trail I use it to avoid the bent presta valves, they do indeed appear to be made from cheese. The adaptor is a couple of quid from LBS.
[url= http://www.winstanleysbikes.co.uk/product/34096/Silca_Presta_To_Schrader_Pump_Valve_Adapter ]link[/url]
Posted : 27/09/2010 1:28 pm
If you drill a bigger hole you [s]WON'T[/s] will be able to go to tubeless.
Fixed that for you. 😉
Posted : 27/09/2010 1:57 pm
Why not just run tubeless? Or alternatively, less hamfistering.
Posted : 27/09/2010 2:01 pm
