TMARS dropper cable...
[Closed] TMARS dropper cable thru V-brake cable mounts?
[#5001126]
Anyone done it?
I'm waiting on the dropper arriving and I was wondering if I can make use of the old V brake mounts on my frame. I guess it's just a standard gear cable and outer?
Can you see any downsides?
Posted : 26/03/2013 11:53 am
you might need to drill the stops out.
Posted : 26/03/2013 12:03 pm
I was thinking about cutting the outer and using the stops as they would be used for brake cables, ie. expose the inner between the stops.
Posted : 26/03/2013 12:19 pm
Only downside is the possibility of extra crud in the sections of outer I'd imagine, same as it is for gear/brake cables.
Posted : 26/03/2013 12:24 pm
