Just took the plunge on a Titus rockstar frame from onone and am trying to source the correct headset
I'm thinking this will fit but am I correct? The headtube appeared tapered in the images of the frame and says it needs a 44mm top to a 1.5 lower
[url= http://www.chainreactioncycles.com/brand-x-headset-44iets-sealed/rp-prod130944 ]
[/url]
Thanks in advance
Based on the 'what other people bought when they bought it' suggestions, I ordered this:
http://www.planetx.co.uk/i/q/HSFOITA/fsa-orbit-ita-headset
I'll let you know if it fits when DHL get around to delivering it...
Thanks that's what I saw was trying to save some cash as didn't really want to spend out on the frame but seemed too good to pass on!
Upper - 44mm ID integrated
Lower - 49.something ID external
Im still T a loss trying to find a headset will give onone a ring tommorow
My mate just got the full carbon version and the headset from his Parkwood fit so whatever that is works.
Thanks for the advice
Zigzag would be great if you can let me know thanks
Hope pick and mix works
I also bought the rock star frame, after seeing a couple of long term test reviews online with positive things to say it was a no brainer for the money.
I wasn't sure about the headset either so phoned today, for a tapered steerer tube the following will fit.
http://www.planetx.co.uk/i/q/HSFSDXPT/fsa-dx-pro-tapered-headset-(acb-bearings)
£29.99 so I just got it added to the order.
Just need to find money for forks, wheels, brakes, gears.......
Glad I pushed the button on the frame yesterday, it's gone up a hundred quid overnight.
Neverown thanks for the reply i looked at that headset and it seemed to me to be for 1 1/8 straight steerer forks? And glad you got one im looking forward to mine turning up
Well if anyone ordered a small Rockstar frame & has a large delivered I'll do you a swap as the sent me a small when I ordered a large 🙁
The bottom ID is 49.7, so the first two headsets linked won't work (they are for 44mm).
Top cup should be ZS44/28.6, bottom one EC49/40 for a tapered fork.
MrOvershoot - Member
Oh well looks like I'm out of luck as there are no Large frames left to get it swapped with 🙁 so its back to On-One for a refund.
otsdr is correct. Picked mine up from their Barnsley store and they checked the measurements and recommended Hope. Staff were surprised at the price at £299, so not surprised they've gone up.
Got my order in before Christmas at 299, got to be one of the cheapest new decent full suss frames I've ever seen. I got Onone to fit a headset prior to delivery. However having seen Mr Overshoots comments, better check that they actually delivered a large now
Ordered a Large on Xmas Day with the big discount, still bloody waiting for it and getting worried it's not going to show. I've dropped them a line...
Zigzag if it's not gone out you are probably out of luck, but given its a Yodel delivery lottery it might just be cruising round in a van?
I'm a bit miffed as its the first time in 12 years On-One/PX have dropped a clanger for me & I have already bought a pair of 120mm Rebas for it which I don't now have a frame to fit to.
I wonder why it was discontinued? Looking on line there seems to be a lot of very similar frames from Taiwan still being made.
Which frame was it for £299? Had a look but the only one showing is the full carbon for £499?
My friend got one of these well before Christmas and they only had small left then.
They still have large frames with no shock in stock could they not sort out swapping the shock from the small frame to a large for you??
MrO - I selected DHL for delivery, rather than Yodel, so I'm hoping that it got stuck in a DHL hub somewhere over the New Year break. Probably dreaming...
Just built up a small for the wife - looks fantastic and a snip at £240. Sorry for you guys who have not had such good luck with this.
Im still hoping to get mine lol
Mr Overshoot, might be interested in the frame.
Email in profile.
bentiggerwyles - MemberThey still have large frames with no shock in stock could they not sort out swapping the shock from the small frame to a large for you??
Well that's changed "again" last night it was there yet when I was talking to O-O this was what I suggested while on the phone they said there was only Med left with no shock & the website reflected that?
Bentiggerwyles, looking at the link to the headset now makes me think they've added the wrong one to my order as it does say 1.5 to 1 1/8 reducer crown race...hmm..
Another phone call tomorrow then.
Edit: djflexure, what headset did you put into the frame?
granny_ring - Member
Email in profile.
Sorry I've arranged for a refund, but with me sending it back there will be a small back in stock.
I have just had a look in my spares box and I have an almost pristine Fox RP3 that is the right size so if they still have the no shock frames in Large and won't swap the shock over from mine its an option?
iirc these were the last of the "proper" Oregon built Titus frames.
Well spoke to onone they said my frames are in picking and should be dispatched today?
Will wait for a confirmation of dispatch email first before beliving as have 1 large and a medium on order!
Ha ben, just did exactly the same this morning. Called them up and asked the helpful chap to check that there was still a Large for me. Order is now in picking... Fingers crossed.
[url= https://www.merlincycles.com/hope-pick-n-mix-headset-cups-55430.html?utm_campaign=googlebase-GB&utm_source=googlebase&utm_medium=shopping&utm_term=Headsets&ucpo=15453&gclid=CK27-7O4lcoCFSoEwwodYxsHyg ]Hope No2 (upper) and F (lower)[/url]
johnnystorm - Member
Ahh that answers it as the frame says made in "Portland Oregon" or something like it.
Anyway it looks like I might have sorted the problem.
On-One are collecting the Small frame & swapping the shock over to one of the Large ones without a shock, I'm still not going to order any other build parts till I have the Large frame in my possession though 😉
Well lets hope everyones frame does turn up
I have had plenty of dealings with onone and always been good to me including some warrenty bits
So heres hoping
Apparently mine is now shipped so fingers crossed! Phoned them this morning about the fsa dc pro and they said it will fit tapered forks, they must come with both crown races or something. Now to decide on forks!
Good to know
That's my order showing as shipped now too. Hopefully it'll arrive tomorrow while wife is at work, and I can spirit it away 😳
Neverown If you can let me know if it comes with both crown races I would appreciate that
Frame landed.
The> http://www.planetx.co.uk/i/q/HSFOITA/fsa-orbit-ita-headset On One's Smoothie bottom cup looks like it'll fit, so that'll be going in instead since I've got that sitting spare.
That ^^^ FSA headset is for a 44mm top and bottom headtube with a 44mm external bottom cup for tapered forks, the aluminium Rockstar is a tapered 44mm semi integrated top 1.5inch bottom tapered headtube,
The full carbon Rockstar might be different though
Zigzag sorry to here that website is confusing as to what will fit!
Ach, my own fault for not doing my homework, ben. I thought it was worth a punt for £16, and I can still use the upper cup.
Just fitted a mix and match nukeproof headset. 49mm internal diameter for the bottom. Just need a seatpost and clamp now
Well Yodel picked up the Small frame to go back today, so lets see if the shock gets transferred to a Large & comes back to me.
