It's not a gear you'll use often, but it shouldn't be like that. I'm in the middle of cleaning mine just now so I'll have a look once it's all reassembled.
Initial thought is perhaps too many BB spacers? There should only be one on the drive-side cup and none on NDS. Assuming its an external hollowtech style BB.
look at your chainline - theres nowt else to tweak to sort it - as long as frame is straight
Initial thought is perhaps too many BB spacers? There should only be one on the drive-side cup and none on NDS. Assuming its an external hollowtech style BBThought it may have been that myself but its the same whether there is 1 spacer in there or no spacers drive side ??
Tony
Just looked at mine and it is fine.
Check you bottom bracket spacers, your cassette is all the way home and the hub (if hope) has not dropped the insert out, as they sometimes do.
Checked cassette is all the way on
Tried xt wheels and a set of mavic crossride , both the same??
and NO BB spacers !! .. still rubs with no spacers or 1 spacer ?
Tony
check pivots & check rear end alignment, is it new or secondhand?
take measurements from both sides of frame (if symetrical) and see if they tally, could run a string from L rear dropout / round seat tube / R rear dropout and measure frame centre (again if rear end is symetrical)
Starting to think it may be an alignment problem 😥
Frames new , just had it imported from the states !
also tried a older chainset , with splined BB and still no better
Here's the clearance on mine in that biggest gear:
[url= http://farm5.static.flickr.com/4023/4391683963_fc33344e48.jp g" target="_blank">http://farm5.static.flickr.com/4023/4391683963_fc33344e48.jp g"/> [/img][/url]
It's only about 1mm but it's enough.
Is your frame second-hand? Possible misalignment?
what **** designed that?
get a refund and buy a specialized
Must be alignment then.
what **** designed that?get a refund and buy a specialized
Thanks for your input.
Indeed. What a ****
speak to Titus
qwerty - Member
speak to Titus
Have just spoke to jensons and am awaiting there views ?
buy a specialized
At least buying a Spesh you know for sure that your alignment will be out 😉
Also worth noting that (on mine anyway) that the only way I could get the chain to stop rubbing in certain gears was to run two spacers on the non-drive side of the BB. Odd but worked. Oh and watch out for cable rub on the rocker/ brace and frame around it if clearance for cables is tight.
