Titanium Seatposts
[Closed] Titanium Seatposts
[#4050638]
I'm looking for a 400mm 27.2 Ti seatpost. I've looked at Van Nicholas but have just found these on fleabay:
http://www.ebay.co.uk/itm/Titanium-bike-parts-Seatpost-27-2-30-9-31-6mm-SlicksandShox-/320852065799?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item76c1b077a7#ht_831wt_1270
And one used one of these, or can suggest a good alternative to Van Nicholas (if there is one)..
Thanks
Posted : 09/06/2012 12:03 am
USE Sumo, fiddly saddle bracket but rides well.
Posted : 09/06/2012 6:13 am
Can't see the Sumo 400mm on CRC or Wiggle, but it exists, I have 1! British product too.
Posted : 09/06/2012 6:16 am
 rob2
I've got a j&l ti post if you're interested? £39?
Posted : 09/06/2012 6:32 am
I have other Ti items from this seller and he has been 100% reliable.
http://www.ebay.co.uk/itm/J-L-UltraLight-Titanium-Seatpost-27-2mm-174g-Road-or-MTB-/280816319833?pt=Cycling_Parts_Accessories&hash=item4161f4fd59
I also have a USE Alien Ti seatpost on a Ti frame, and whilst the cyclops clamp was fiddly, once done it has been perfect...bought off here.
PaulD
Posted : 09/06/2012 6:35 am
Yeah as Paul says the Sumo clamp is solid once set. Wouldn't be an easy trailside adjustment tho, I can only assume Thomson have a patent on their design or everyone would use it.
Also worth noting the Sumo has a small offset, 6mm I think, may be relevant for your fit.
Posted : 09/06/2012 7:32 am
I bought a Van Nic one a while back......... it bent after a few rides, immediate refund from On One tho. Qoroz do a nice looking one that comes with a lifetime quaruntee.
Posted : 09/06/2012 9:19 am
How did you manage that?
Ive had an On-One van nic one for a year or so and I weigh 95Kg+ and am clumsy as f*** and it just "gives" a little. Very nice ride it is too.
Posted : 09/06/2012 9:23 am
Dunno whether these are any good, but the the twin bolt clamp looks a bit more solid than the USE set up.
http://www.ebay.co.uk/itm/Titanium-bike-parts-Seatpost-27-2-30-9-31-6mm-SlicksandShox-/320852065799?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item76c1b077a2
Posted : 09/06/2012 9:28 am
my Van Nic has a slight bend in it also. It is the lay back version, it is slightly more lay back now.
Posted : 09/06/2012 10:18 am
USE is fiddly but I have had no reliability issues, after 50ish rides.
It's nice and flexi. Personally I'd be reluctant to buy a no-name brand via ebay, seatpost is an important bit of safety kit. (I had a carbon post splinter beneath me once, I was very lucky not to get eviscerated).
Posted : 09/06/2012 10:24 am
Again my van nic, a really lovely ride, great flex.... Bent whilst on my Fargo on the south downs way.
This was after a year and 100kg of me.
It's now cut down and ony cross check.
Ti can make an excellent post, real comfy flex, but there is not much choice at a realistic price.
Posted : 09/06/2012 10:25 am
Yeah, the flex was lovely till it flexed beyond its ability to return. It was run almost to its max extension mark on a 400mm post.
Posted : 09/06/2012 11:11 am
Does anyone do a steel post ?
I know, would potentially rust, but we have mild EN1A plated & it happily sits under road sweepers for years.
Posted : 09/06/2012 11:52 am
Id better keep an eye on my van nic then.
Pity their warranty is only one year on components though 🙁
Posted : 09/06/2012 12:06 pm
Keep an eye on Ebay for bargains, I managed to get a nearly new Moots cinch for £85.
I used to have one of the Van Nich posts that was as good performance wise bar the seat clamp that is a bit of a hassle to change saddles.
Posted : 09/06/2012 12:19 pm
I have a Kent eriksen it's lovely life time warranty
Posted : 09/06/2012 12:33 pm
What's all this about the sumo being a fiddly design? It's a single bolt pivot design, it works flawlessly and looks great.
Posted : 09/06/2012 12:42 pm
Thanks for the replies guys. I think i might give the ebay one a go. I tempted by the Van post but didn't realise so many were bending. Especially as it's the bent one i was thinking about.
It's for my Cotic Soul. Maybe a carbon post??
Posted : 09/06/2012 12:50 pm
I have an older use alien with the suppossedly fiddly alien clamp but.it.seems.OK to.me. with flite flow saddle.on titanium rails with the split in the middle there seems to be quite a lot of bump absorbtion.
Yes get a carbon post since they're lighter/stronger/cheaper?
Make sure you dont get a USE one though.
Posted : 09/06/2012 12:58 pm
I bought a Sumo and its a piece of p to set up.
USE, in non fiddly set up shocka.
Posted : 09/06/2012 1:32 pm
mattjg - Member
According to the USE site they don't do a Sumo Ti in 400mm flavour :o(
http://www.use1.com/product/000053/sumo-titanium-/
Posted : 09/06/2012 1:49 pm
how about :
http://kenteriksen.com/seatposts/
megabucks but look nice. They do international orders.
Posted : 09/06/2012 1:58 pm
ok could be mine is a 350, soz. 400 would be looooonnggg!
Posted : 09/06/2012 7:23 pm
I have a photo somewhere of my broken carbon post, if I could find it, it would put you off a carbon post forever.
I run the USE Sumo Ti in my small Soul btw. It's not bent.
Posted : 09/06/2012 7:27 pm
18bikes are working on a steel Reynolds 953 post.
Posted : 10/06/2012 12:45 am
The Syntace P6 HiFlex one reviewed in WMB looks good. Expensive, strong flexy carbon?
Posted : 10/06/2012 9:07 am
