tiny pin
[Closed] tiny pin
[#2459925]
you know that fiddly tiny pin on the hope tech x2 brake pads..well mines seems to have fallen out....will the bar hold the pads in ok ? or shud i try to get another pin from somewhere... 😉
Posted : 11/02/2011 4:09 pm
I use a dinky little safety pin on mine.
Posted : 11/02/2011 4:15 pm
the R clip is belt and braces. Even had a pin come loose and be saved by the R clip on the end? If so, you need it. If not, don't lose any sleep.
Posted : 11/02/2011 4:16 pm
so will it be ok ? lol..it cud have been missing a while who knows.searched my spares..i have the 2 spare bars and the spider thing thats holds pad together bit no spare pin....they are sods them little pins... 😉
Posted : 11/02/2011 4:24 pm
If you're worried, a bit of fuse wire would do the trick but in reality, I've never had one of those come loose so the R clip (wiggle wire thing) is surplus to requirements.
Posted : 11/02/2011 4:27 pm
If you are worried, just buy a set of genuine Hope pads, you will need them eventually anyway, they come with spare pins and retention bars.
I lost the pins on my brakes the day I fitted them. Been using them fine without for a few months now.
Posted : 11/02/2011 4:28 pm
Ive never had a pin come loose. I usually have the opposite problem.
Posted : 11/02/2011 5:01 pm
I would have worried about it on the old Mono Mini's but the X2 pins screw in so I wouldn't worry. If you really want belt and braces use any old bit of wire
Posted : 11/02/2011 5:05 pm
yep i,ll use wire in future if lost pins !...but hey i found a spare pin on the floor ! problem sorted 😉
Posted : 11/02/2011 5:23 pm
 momo
I've lost them in the past and used fuse wire to secure the pins.
Posted : 11/02/2011 5:26 pm
It may be belt and braces, but that is what a safety critical system requires. As mentioned, just replace with a bit of fuse wire.
When replacing worn brake pads (or bike bits in general) it's always worth retaining such bits for this sort of scenario.
Posted : 11/02/2011 5:29 pm
