So, the entries are open tomorrow. No straight bars, discs are ok. Any ideas if I can use midge bars? Can't see anywhere where it says max bar width, just says drop bars.
Max width will probably be as specified in the BC handbook, which you can access online.
I think it used to be 50cm
Max bar width is 50cm regardless of the shape of them. Drop bars only this year.
Rules can be accessed from here: http://www.3peakscyclocross.org.uk/race_info.htm
Any bars with a total width of 50cm or more are banned.
There's been lots of debate on the 3 peaks forum, those with bars wider will be unlikely to slip through the net this year.
Cheers people, ok next question. Where can I get very shallow drop drops from then? 😀
Loads do em, ritchey, fsa, planet-x etc dependant on budget.
