Thread pulled out o...
[Closed] Thread pulled out of post mount.
[#10282388]
Building up a shopper last night On  tightening the brake bolt it went tight then loose.
Trying to undo the bolt it just spun so I managed to pull it out.
The bolt seemed to have the fork thread attached to it. Never had that happen before. They are 10 year old Marzocchis.
The other bolt is fine.
Any one have a fix?
Posted : 18/10/2018 10:14 am
longer bolt?
thread further in may still be there.
(don't let any new bolt bottom out though)
Posted : 18/10/2018 10:17 am
helicoils were made for this.
Have helicoiled my ibis frame top mount for similar reasons and its solid.
I have successfully helicoiled a brake mount on an old set of Floats where I did the same thing, they are still working on a singlespeed winter hack ~10 years on.
Posted : 18/10/2018 10:18 am
Excellent is the M 6 size listed above the size I need?
Posted : 18/10/2018 10:22 am
Helicoils/inserts are better than the original design of cut cutting the thread into the casting - so you're really getting an upgrade.....
Posted : 18/10/2018 10:31 am
Would helicoil if it was mine. Have told a shop when this happened to a new fork that no, a longer bolt wasn't going to work (it will be quite close to bottoming out, you won't get much thread engagement, if it's failed already with decent thread engagement you will have to go very easy on it in future. Brakes being attached to my bike when I need them is quite useful.)
Posted : 18/10/2018 12:35 pm
