What's the right way to apply them?
Posted : 21/12/2013 12:36 pm
lightly sand the area..
stick the patch on..
i find it helps to have the tube slightly inflated.. and then apply some pressure to the patch with both of my thumbs after its stuck on..
same as a normal patch to be honest.. just without the vulcanising solution..
Posted : 21/12/2013 12:39 pm
IME you need to sand scrupulously.
Posted : 21/12/2013 12:43 pm
Fit new tube, save Park patch until your hydration bladder leaks.
Posted : 21/12/2013 12:48 pm
Those park patches are great but if its next to the seam of the tube then they tend not to work.
Also put them in a small plastic zip bag to keep them dry. If they get wet at all then the glue is a bit dodgy.
Sanding it down to get rid of grease etc is the secret
