Thomson stem bolts ...
[Closed] Thomson stem bolts - where to get some?
[#5480425]
Need two new steerer clamp stem bolts for my Thomson stem. They're 24mm long and 4mm diameter thread with sweet tapered allen key heads.
Where can I get some?
Posted : 03/09/2013 9:38 am
CRC used to sell spares.
Posted : 03/09/2013 9:40 am
i have a bag of 6 if you want them for postage? email in profile
Posted : 03/09/2013 9:42 am
rob jackson, are they silver? are they the same as the ones i need to replace?
Posted : 03/09/2013 9:45 am
Stem is an Elite X4 and the bolts look like this.
[url= http://farm6.staticflickr.com/5510/9660328127_433fa49e1d.jp g" target="_blank">http://farm6.staticflickr.com/5510/9660328127_433fa49e1d.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/cakefest/ ]cakefest[/url], on Flickr
Posted : 03/09/2013 10:24 am
They look like ti ones - certainly not the standard bolts.
Pro-Bolt are excellent for replacements if you want to continue with something a bit fancy!
Posted : 03/09/2013 10:36 am
not sure what 'M' size these are. how do i work that out?
Posted : 03/09/2013 10:44 am
I'm trying to remember what I ordered! Need to check when I get home. Think they were M5? Is not stamped into the top of the bolt head?
Posted : 03/09/2013 11:09 am
no, nothing stamped into these bolts.
Posted : 03/09/2013 11:14 am
Okay, I'll check when I get home.
Posted : 03/09/2013 11:22 am
'M' size = thread diameter.
That said, I thought Thomson stems were M5s, but you've measured them as 4mm.
Posted : 03/09/2013 11:54 am
M5
Posted : 03/09/2013 12:01 pm
yeah, on 2nd measure they look more like 5mm.
does the length measurement run from the base of the tapered head to the end of the bolt? 20mm in this case.
Posted : 03/09/2013 12:03 pm
Indeed it does, so you need some M5x20mm bolts in your chosen material, avoid aluminium!
Posted : 03/09/2013 12:06 pm
And plastic.
Posted : 03/09/2013 12:11 pm
