Quick question- Do I need to grease or not?
Posted : 31/03/2012 4:11 pm
In a steel or alloy frame, yes, but a light film will do. (More about stopping it corrodong into the frame than getting it in and out easily).
Posted : 31/03/2012 4:21 pm
thanks
Posted : 31/03/2012 4:28 pm
Depends. Will you move or remove it much? Mine come out regularly so I run them dry on the mountain bikes. The one on the road bike never moves so that has copaslip on it.
Posted : 31/03/2012 4:30 pm
If you're a serial saddle dropper and its wet/muddy or really dusty out (so not the UK .. ), then greasing the post can attract loots of crud and make it harder to get the saddle in/out
Though no grease will wear out the post/seattube quicker (if a serial dropper/raiser)
Posted : 31/03/2012 4:33 pm
Q – Should I grease my seatpost before installation?
A – A very light coat of grease is okay. Do not use anti-seize as it can lead to slipping. To prevent sticking the post in the frame, remove clean and re-install every 90 days. Do not use grease in a carbon fiber frame.
http://bikethomson.com/seatposts/elite/
Posted : 31/03/2012 4:43 pm
