Thomson h/bar clamp...
[Closed] Thomson h/bar clamp plate cracking - anyone else!?
[#696180]
I seem to have split the handle bar clamp plate on both my Thomson stems. I guess I must have been overtightening them, I didn't think I was overdoing it to be honest. I've got replacements on order btw. I know I should own a torque wrench and set them at 5.5Nm before anyone states the obvious.
So, a common occurance?
Posted : 09/07/2009 3:57 pm
Hell no!
Posted : 09/07/2009 3:58 pm
Not here - think you might be overtightening them as the do have a specic max torque on the stem itself!
Posted : 09/07/2009 3:59 pm
nope - not after years of cranking one on an SS either...
Posted : 09/07/2009 6:35 pm
Yep I've had one crack.
They warrantied it for me.
Posted : 09/07/2009 6:56 pm
I had one crack, but they only cost a few quid.
Posted : 09/07/2009 7:15 pm
I've had Thomsons on almost every bike I've had over the last 8 years or so and I've never even heard of it happening! Must be some serious over tightening going on!
Posted : 09/07/2009 7:24 pm
no cracks after many years of Thomson ownership... I think their stems & posts are the best...
Posted : 09/07/2009 8:50 pm
Interesting - just borrowed a torque wrench and I was surprisingly close to the 5.5Nm recommended, if anything a fraction under.....the mind boggles, but as already said at under eight quid I won't be losing any sleep over it. More of a safety concern.
Posted : 09/07/2009 11:31 pm
Only the three of us.....checked a mates yesterday, and unbeknown to him his had a crack too!
Think they are great products, just not as fit and forget as we may imagine, plus CRC must stock those little bits for a reason..........
Posted : 10/07/2009 10:12 am
Thomson in "less than perfect" shocker!!!
Teh fanboys will be sweeping this under the carpet!!!
Posted : 10/07/2009 10:15 am
over-hyped, over-priced .. nice kit but people have this idea that they are indestructible.. evidently not.
Posted : 10/07/2009 10:16 am
Maybe you are not clamping it evenly a bit at a time on each bolt?
Nothing is indestructable and your right they sell the bits for a reason...
What they are very good at is keeping a very nice finish for a long time.
Posted : 10/07/2009 10:34 am
Yeah, form over function is the way to go, eh?
Posted : 10/07/2009 10:39 am
Thomson fanboys outed!
Posted : 10/07/2009 10:42 am
Bigots rule OK 😉
How big are the bolt heads, out of interest?
I've just bought a Nuke Proof (£55), and was surprised that the bolts are 4mm allen key I think. That really makes you think about whether you should be swinging on them to do them up. 🙂
Posted : 10/07/2009 10:45 am
Nah not form OVER function but form WITH function.
The Elite stem has the function, form and even safety built in, with the steerer clamp bolts not in the knee/nut zone... They should have used the same method on the X4.
edit... woodsman, where is the plate cracked? Any pictures?
Posted : 10/07/2009 10:59 am
(Mr MC posting) are you torquing them up in the right order? For any application where multiple bolts hold components flat youre supposed to work opposites, so if you numbered the bolts clockwise you'd tighten 1, then 3, then 2 then 4.
First came across this re-fitting a cylinder head to an engine but it holds for all such situations.
Personally never heard of ANY stem plate breaking.
Posted : 10/07/2009 11:02 am
I cracked one on my X4, correctly torqued up no less too.
Got a new one under warranty.
Posted : 10/07/2009 11:04 am
I'm quite used to the cylinder head torque sequence so, no that's not to blame. I'll post up a pic soon, once I've hosted it etc. Cracked in the middle, lateral, same on my other bike, also crack in the steerer clamp too (microscopic) same as a mates. Think I've been riding with it like that for ages. Only reason checked, was that I jumped a couple of flights of concrete steps after a eve ride, and something didn't feel quite right after - not as hardcore as it sounds, honest!
Posted : 10/07/2009 11:52 am
As above, you need to make sure that they're all torqued up correctly but arguably more important is to ensure that the face plate has even gaps between the face plate and the stem (ie left and right) on both top/bottom. It's very easy to torque the bolts properly but to have the face plate permanently twisted by not having even gaps - this will likely cause cracking eventually.
Posted : 10/07/2009 11:57 am
Yeees, thanks but stating the obvious there clubber.
Posted : 10/07/2009 12:12 pm
Ferk, its not even come from and edge at all, looks to have started in the middle, rekon Thompson would be interested to get that one back, and I would imagine/hope give you a free replacement.
To me, it looks like a flaw in the metal itself...
Posted : 10/07/2009 12:16 pm
Yes it is but you'd be surprised how many expensive stems I see with uneven gaps (and by uneven I mean something like 0.5mm+ so not massively out of line.
Posted : 10/07/2009 12:17 pm
