Thomson dropper pos...
[Closed] Thomson dropper post sticking
[#7577274]
I've had my dropper post for a while but last cold wet muddy ride it has started to stick. It seems to go down and comes back up but only half way then you have to pull it back to the top.
Anyone have any experience in stripping or re greasing their posts ? Any advice needed! I know I should send it off but I'm skint after Xmas
Posted : 13/01/2016 9:08 pm
Failed cartridge. Happened to mine twice, although it was only the last cm or so.
Not user serviceable so it's off to iRide for a service unfortunately.
Posted : 13/01/2016 9:23 pm
Mattbee what was their service like? Any other options for service other than those guys
Posted : 13/01/2016 9:26 pm
They are the Uk importer, no idea if anyone else has access to parts.
Service was pretty good, Oli there who deals with it is a good guy. I had the full service done so £90 and got new cartridge, bushes, collar & ended up with a new upper post as it was scored below the seal. Only the lower post, clamp and lever are the original. Rest all new, not bad for £90.
That cartridge failed & was replaced under warranty. Been fine since.
Both times turnaround was about a week.
Posted : 13/01/2016 10:06 pm
I've had the same happen to two of mine now - the 2nd one is back under warranty - less than 4 months since it failed last
They were a little slow the last time but hoping they are quicker this time
They're a long way behind SRAM in turn around time but its a much nicer seatpost and a lot more reliable than a Reverb
Posted : 13/01/2016 11:08 pm
Matt - how much of that work was just classed as 'normal service', and how much was warranty-type failures?
Posted : 14/01/2016 10:03 am
I can't help but think that it must be possible to disassemble and clean/regrease sliding components, even if you can't get into the cartridge. Someone somewhere must have done it.
Posted : 14/01/2016 10:07 am
Bindun (but in foreign):
[url] http://happymtb.org/forum/read.php/1/2857541 [/url]
The google-translation is actually pretty decent, though.
Posted : 14/01/2016 11:13 am
Minecwas second hand so I had to pay for all of it. The bush and top cap replacement I had done as I thought I may as well since they had it but the cartridge would most likely have been under warranty if I was the original owner, I'd imagine.
Posted : 14/01/2016 2:25 pm
Cheers warpcow
Posted : 14/01/2016 2:38 pm
Just had a warranty repair from Thompson returned in less than 2 weeks - bravo Thompson - thoroughly impressed - quicker than Sram 🙂
Posted : 22/07/2016 2:16 pm
who is the best peson for servicing thomson droppers in the uk? (yorkshire)
Posted : 22/07/2016 7:19 pm
iRide are the importer so probably them. Full service inc cartridge & bushes etc is £90.
Mine has now been back 4 times for the same cartridge failure.
Posted : 22/07/2016 7:29 pm
