Thomson dropper odd...
[Closed] Thomson dropper oddness – any ideas?
[#6809922]
First ride with a dropper post today – a Thomson Covert. Lovely smooth action (no, that's not a euphemism) but when I moved the post further up to get proper leg extension, the dropper bit wouldn't stay extended. Annoying.
Now, I read something about needing to make sure that the cable (outer and inner) was kept slack when you move the seatpost up, which makes sense. So I may just need to feed a little more cable into the seat tube. Is that anyone's else's experience?
Also, anyone had problems slipping down into the frame?
Posted : 25/01/2015 10:50 pm
Sounds like the cable is actuating the drop slightly. A bit more cable/outer is probably needed. Had similar on mine and it doesn't take much to engage the actuator
Posted : 25/01/2015 11:05 pm
Cheers Stevied.
Posted : 26/01/2015 8:30 am
