Just got one of these but noticed that the remote cable supplied is a little short for wide bars. Is it just my strange way of running cable or had anyone else had this problem. Supplying a bit more cable is not much to ask is it. Back to the shop.
[quote=RV ]Just got one of these but noticed that the remote cable supplied is a little short for wide bars. Is it just [b]my strange way of running cable[/b] or had anyone else had this problem. Supplying a bit more cable is not much to ask is it. Back to the shop.
Details would help?
Easton carbon havoc 150's, Thomson 80mm stem and a medium SB66....
That's are very narrow bars.
Still not that clear...no mention of where you are running the cable etc.
However, I imagine that if it was along the top tube then yes the cable does seem a bit short.
Be very interested to hear how you get on with it. I'm thinking of getting a dropper and the Thompson up on my list..
I think everyone will be interested in hearing about this.
Sorry the bars are 750's. There is a spare cable routing lugs on the underside of the top tube which I was going to use but I'm short about 5 inches of cable.
I've done about 5 rides on one without the remote and stands up very well to the competition. Still has no play and feels good straight from the box. It's fairly light and looks great on a black frame with gold Kashima fox forks and shock.
Did yours come with just the remote or did the under-saddle lever come with it? I saw that Thompson were going to be supplying both but it now seems like it's remote in the box, under-saddle lever extra 👿
Under seat lever is not yet available yet, even the posts are in short supply with crappy margins. the lever when available is going to be £40.
Has the design of the remote changed since the demo ones were around? That one looked a bit 'sharp'..
Slightly off-topic;
I emailed Thomson the other day asking when their fabled 27.2mm diameter dropper would be out.
"It's looking like the fall" was the response I got back.
So I've finally got round to fitting up the remote once I'd got hold of some more cable inner and outer. It all fits up very well, though the cable retaining grub screw is very small and fiddly (also a nightmare to find if you drop it. I am going to play around a little with the positioning of the lever which does look sharp and which I'd like to get out the way so that it's unlikely to take an impact if the bike and I part ways. Took it out for a spin last night in the rain and mud and all working well. The movement is super smooth and works really well. I really think that this will up the bench mark for dropper posts.
[URL= http://i174.photobucket.com/albums/w81/randyvegas/141f9cea-4358-468e-8ce2-c2ea40559d35_zps98d46afb.jp g" target="_blank">
http://i174.photobucket.com/albums/w81/randyvegas/141f9cea-4358-468e-8ce2-c2ea40559d35_zps98d46afb.jp g"/> [/IMG][/URL]
[URL= http://i174.photobucket.com/albums/w81/randyvegas/79e30625-756c-4cf8-a875-7518964d5078_zpsbcc060e5.jp g" target="_blank">
http://i174.photobucket.com/albums/w81/randyvegas/79e30625-756c-4cf8-a875-7518964d5078_zpsbcc060e5.jp g"/> [/IMG][/URL]
[URL= http://i174.photobucket.com/albums/w81/randyvegas/7a0d0588-ca78-4e2a-a696-0121d00791c1_zpsb180e32f.jp g" target="_blank">
http://i174.photobucket.com/albums/w81/randyvegas/7a0d0588-ca78-4e2a-a696-0121d00791c1_zpsb180e32f.jp g"/> [/IMG][/URL]
[URL= http://i174.photobucket.com/albums/w81/randyvegas/f56a584c-3aa8-4e73-af06-3d60be4593f0_zpsf5e90325.jp g" target="_blank">
http://i174.photobucket.com/albums/w81/randyvegas/f56a584c-3aa8-4e73-af06-3d60be4593f0_zpsf5e90325.jp g"/> [/IMG][/URL]
Why? It still has a flappy bit of cable, a slightly vulnerable looking actuator mechanism, a less than ideal lever on the bars and to top it all is supplied with a cable that's too short. Oh and it's about the most expensive out there.
They claim to have put a lot into the innards, but only time will tell how they actually compare in use.
Nice to see a dropper that has a nice elegant saddlt clamping arrangement too.
I don't fancy your chances of the remote cable staying gunk-free in that position, at least one the KS Lev you can have it on the front of the post
Have you thought about putting one of the shimano rubber covers on the cable to stop the gunk flowing down the cable under the seat where the cable exits?
Not what i'd call a UK-friendly design. 😯
saw this on the leisurelakes site:
5 inches/125mm of infinite travel.
que?
ph - It will mean infinitely adjustable rather than pre-set heights.
As soon as the under seat lever is available I'll be fitting that to be fair as I'm not keen on the extra cable anyway. There is a stealth internal cable version in design at the moment but your bike had got to be accepting of it.
is the lever not too bar inboard to reach with your hand on the grip? I've got my reverb remove on the underside right next to the grips so it's in the perfect position for adjusting on the fly.
pp- hmmm. ta fer that.
at three hundred squid however, i'll never get to use one anyway...so moot point.
Oh, rubbish.
I had visions of pressing the remote and seeing the saddle disappear up into the clouds Jack-in-the-beanstalk fashion 🙂
Why does it have a travel indicator O-Ring?
Go-go gadget seatpost!
No idea why it has an O-ring??
[i]'I really think that this will up the bench mark for dropper posts'[/i]
I'd argue its the reverb. Why would you want a cable when you can have a great feeling hydraulic button. I think they are miles ahead especially if you have a stealth one.
There is so much exposed cable begging to get covered in mud and then inside the outer cable it goes.
andysandes - MemberWhy would you want a cable when you can have a great feeling hydraulic button
Because cables are simpler, easier to work with, easier to get spares for or bypass. Hydraulic is nice when it's working but I broke the lever on my KS in a crash in the alps, I just removed the cable entirely and operated it manually at the post end but if I'd wanted to fix it, I could have got every part required from any bike shop in the world for a couple of quid. Good luck with either of those with a reverb.
I saw a chap at glencoe who knocked the hose off his Reverb on the chairlift, then discovered he couldn't drop the seatpost at all. That's not really ideal there.
Agree with most of the above. Even if they come out with a 27.2 to fit my frame I wouldn't want one with a bit of cable stuck out there. Not only because of the filth, but it looks rubbish!
[edit]although good points by northwind above 🙂
How light is it exactly... is this where it makes inroads into the opposition?
hydraulics are plusher but at a faffage cost when it goes wrong
Not read a thread from Gravity droppers about broken levers
You lot will be wanting pneumatic gears next as the end of that cable gets a bit muddy as well
Shimano Airlines, anyone? Yes, please!
Or, what about this little beauty?
http://www.pinkbike.com/news/Pinkbike-First-Look-Acros-AEG-11-MT-Hydraulic-Shifting.html
It's a good looker but the KS Lev still looks like the dropper to beat for me.
Could he not have just bled out all the fluid?
really struggle to see why anyone would buy a dropper post thats not been tested in the real world for an extended period of time, for twice the price of a Reverb.
Sure it looks great, and its made by thompson, but they're not exactly proven when it comes to making this kind of thing. Likewise don't they all feel super smooth on the first few rides? (other than the gravity droppers, which ironically are the only ones that seem to last forever).
Interested to see feedback in 12 months, because it is a nice looking piece of kit.
It's a nice looking thing and it'll be interesting to see how it holds up long term.
I've got a Reverb and have been really pleased with it so far but do worry about the cost of replacing the hose which seems totally OTT compared to what I paid for it. I'm just glad I didn't cut the hose when I installed it on my SX or the switch to my Banshee frame would have cost a whole lot more.
4 years ago it may have been a contender, now its just a bit of bling for brand whores, cable = problems.
patriotpro - MemberCould he not have just bled out all the fluid?
The fluid had done a good job of bleeding out itself, what with the rather fragile hose breaking off 😉 It was stuck at full height. I think he found a bodge for it eventually.
[i]bling for brand whores[/i]
How can you say such a thing? About Thomson??! 😆
its an apple mac in a PC world
Surely its a Mac Pro, Junkyard. It's round, expensive, spec looks similar to other offerings but those that buy it will love it... until they bring the new model out.
i bow to your superior knowledge of all things shinny and expensive
The price is pretty eye watering but it is for most other dropper posts at full price too. At least the lever isn't as hideous as the Fox thing....what were they thinking?
To be fair I didn't pay retail for it and thought it looked nice. Only time will tell whether I've made an error or not.
