Thinking of changin...
[Closed] Thinking of changing forks - advice please?
[#2238981]
Hi guys,
I ride a 2008 Felt Compulsion, which has 140mm Rockshox Pikes. The head angle is quite steep, so the bike feels twitchy. Im going to get a shorter stem, and was thinking of changing the forks for 160mm ones, as my mate said that more travel would mean a less steep head angle, so less twitchy?
With regards to the axel, as mine has a 15mm axel now, what happens/what do I need to change if I get forks with a 20mm axel?
Thanks,
Chris
Posted : 30/11/2010 1:38 pm
69 degrees isn't steep.
Posted : 30/11/2010 1:42 pm
 JonR
Can you get a 15mm axle to fit Pikes?
Posted : 30/11/2010 1:44 pm
What length is your current stem? - Twitchy can also be d.t. wide bars & long stem - also your weight maybe too far forward with a long stem?
I'd start with the cheap option so try (borrow if you can or classifieds cheapies maybe) a shorter stem and maybe some wide bars. 160mm over 140mm forks will only take around 1 degree from the head angle so not a huge change. The cotic website has a little calculator thing for their frames but it gives you a good idea of what happens with the changes in fork length etc.
Posted : 30/11/2010 1:47 pm
changing the forks to change the geometery isn't always the best move imo. a longer fork will also raise the bb, which will make the bike less stable; counteracting what you are looking for being twitchy.
pikes are all 20mm
Posted : 30/11/2010 1:48 pm
Shorter stem, wider bars even a bigger front tyre can all help without splashing out wads of cash.
Or maybe a Cane Creek Angleset, not quite available yet but it's a headset that allows you to change head angle.
Posted : 30/11/2010 1:58 pm
Nice one cheers guys! Will get a shorter stem 1st off then, as I think the Pikes are quite a good fork! And thanks for correcting me on the axel size 🙂
Posted : 30/11/2010 2:19 pm
