The new Aluminium S...
The new Aluminium Scandal 29er from on one / planet x
Brake hose goes through the *big* hole on the right hand side, surely?
I'm afraid to say I found it the easiest internal routing I've ever used? (not rubbing it in, I know the stress!).
Posted : 19/05/2020 7:04 pm
I found the cable routing on my scandal one of the best and easiest bikes I've ever done! Just don't drop the screw.
Have you removed the bb?
Posted : 19/05/2020 7:05 pm
I made the assumption that the dropper would go through the individual holes in the down tube as they are the same as the hole in the seat tube. Guess the issue would remain whatever I tried to thread through it!
I will try dropping the cranks and bb out tomorrow and see if that helps me get it through from top to bottom.
Posted : 19/05/2020 8:06 pm
Easiest internal routing I’ve done too. Obviously the black plug(unscrew pop out) feed cable from opposite end. Dropper I fed up from bottom to black removable plug all good. As mentioned getting screw back in to secure grommets bit fiddly but no drama.
Posted : 19/05/2020 8:17 pm
Why does removing the BB make the routeing any easier?
NB I also ran the dropper cable through the single hole on the right of the downtube. All worked pretty well - I did that one from the top down to the removable cover and hooked the outer out with a hook pick.
Finished the build today. Need to adjust the saddle angle, and probably take a couple of links out of the chain.
null
null
null
null
Posted : 19/05/2020 11:51 pm
 cp
What bars have you got on there? They look a nice shape.
Having sold off a chunk of bits having cancelled my build.... I got to the frame to sell and thought... Hang on.
So the build is back on!
The gravel bike might need to go.
Posted : 20/05/2020 10:04 am
They’re some RSP carbon ones from a PSA a few years ago. Been fine for me but a few on here reckon they can be cracky.
Posted : 20/05/2020 10:58 am
@hamishthecat I have also bought a large andwas hoping to fit the crank brothers 170mm. I am worrying about fit and adjustment as it has a long insertion length.
Do you know if it can fit right in so the collar is at the seat clamp? In theory it should but wasn't sure if the bend in the seat tube would prevent it.
Posted : 20/05/2020 1:32 pm
I’m running crank bros 170mm on my medium scandal no issue. I do have very long legs though !
Before I tightened mine up it slid almost down to the collar so reckon you’ll be fine on large
Posted : 20/05/2020 1:35 pm
Yes, likewise - it dropped right to the collar before I’d tightened the clamp so it will fit no problem.
Posted : 20/05/2020 3:06 pm
Fresh set of eyes and a better torch than my phone and it took 2 min to sort the dropper cable routing.
Now finished the build. Forks and dropper from Alltricks, eBay Whyte wheels, GX/Guide groupset from the shed along with the bars and stem.
It’s a size L, I’m 6’2” with a 34” inside leg and it feels fine size wise with a 40mm stem. Think the XL would have been a bit long although would have been less post showing! (That’s a 170mm drop so I guess a 200mm would fit easily).
Wont get to ride it until next weekend mind, too busy with work!
Posted : 21/05/2020 2:53 pm
Looks good 👍🏻 I’ve got my rear brake and dropper opposite way from yours maybe why it was slightly easier to route ?
Love the orange outer on shifter ! Pimp 👌🏻
Posted : 21/05/2020 3:10 pm
Lol, orange outer was all I had in shed, left over from my last road bike! (Well, there’s a load of pink from the Mrs’ bike but that would be a little odd.)
As far as the cables go, I thought it was supposed to be like that as the ports match the one on the seat post but I guess it doesn’t matter that much.
Posted : 21/05/2020 4:12 pm
I had to add, I've been out on mine today on my local trails. Dry, wriggly short sprints on wooded singletrack and lots of park paths and suburban bridleways. It's an abolute flying machine, I love it.
Posted : 22/05/2020 10:02 pm
I bought one from the original pre-order batch and was very happy with it. Sold on now as wifey moaned about too many bikes....Im 5'10 and if I was to do it again I would buy an XL and go with a sub 50mm stem. Cable routing was fine, a bit rattly... but solved with a bit of insulation tape. Yes paint is very thin but at 150 notes it was a no brainer. Great winter hardtail for where I live. Having said that I now spend 75%+ of my MTB time on the ebike.
Posted : 23/05/2020 1:32 pm
null
First ride today - 20 miler from home. Certain amount of confirmatory bias no doubt, but really like it and even got a KOM. Running it 27.5+ and managed to pinch puncture the rear on the KOM effort... Fortunately my multitool has an 8mm key on it as I had to put a tube in.
Posted : 23/05/2020 5:10 pm
If anyone bought a Large and is having second thoughts, let me know I'll buy it rather than you send it back etc.
Either with/without the carbon rigid fork. Not fussed about any cosmetic damage. Cheers.
Posted : 23/05/2020 6:59 pm
First proper ride today. Good mix of singletrack rough and smooth. Accelerates well on 27.5(tyres from spares box 2.1’s are lethal !! Reckon 2.6’s is way forward for grip and bit cushioning 🙂
[url= https://i.postimg.cc/CLTt5KvX/DA774112-DE65-42-FB-9-E18-31788964-BD7-A.jp g" target="_blank">https://i.postimg.cc/CLTt5KvX/DA774112-DE65-42-FB-9-E18-31788964-BD7-A.jp g"/> [/img][/url]
Posted : 23/05/2020 7:53 pm
Finally got mine out for a 20 mile test ride today...bloody brilliant bike.
The rear brake mount is a bit awkward to get to, but other than that no complaints that my fault.
Bike
Posted : 25/05/2020 8:35 pm
Hardly been off mine these past six months or so. I was finding it just a touch too harsh so swapped the lock ons for some slide on with hairspray ones, and I've replaced the Fizik saddle with a digital camo Charge Spoon which feels like it's made a huge difference. Tempted to try it on a set of 27½ plus size wheels and tyres if it doesn't actually make a lasting improvement.
It's taken a bit of tweaking here and there but I'm really enjoying it.
Think my total spend is still under £500, and there's no way I could buy anything comparable for that.
[url= https://i.postimg.cc/F1rHmNCy/20200525-141644.jp g" target="_blank">https://i.postimg.cc/F1rHmNCy/20200525-141644.jp g"/> [/img][/url]
Posted : 25/05/2020 10:40 pm
 cp
Liking the blue highlights there 🙂 think my cheap blue grips will be ok!
Posted : 26/05/2020 10:27 am
Ive been toying with the idea of a B+ rear wheel as well, bit of comfort and to lower/slacken it just a touch.
Only reason Ive not really is the Fulcrum's are fine and I already have a set of 29x40mm rims ready to build up, just need to choose some hubs.
Anyone aware of any bargains?
If like some purple Hope Pro4's
I have a spare set of Hope Pro2 Evos, but they would need a new microspline freehub, 12mm addapters, 15mm addapters, and boost addapters, which makes them actually quite expensive and I'd earmarked them for the next road/cross wheelset.
There's some complete DT 370 32h micro spline rear wheels on ebay for £140, which seems like the cheapest way of getting DT hubs, but not sure about the 18t ratchet.
Or there's the chinese/tiawanese option, but novatec, bitex and powerway dont seem to do micro-spline yet and im reluctant to step outside what I know too much. Koozer do some interesting stuff including a 300g DT style ratchet hub sprung with magnets! But the 12s freehub is only available as an add on so they end up £120 for an unknown.
Posted : 26/05/2020 10:49 am
 D0NK
gone mine built up* and ridden, no pics but who cares, not got a dropper post sorted yet, old school qr, but I've mainly been exploring local stuff so not needed to drop saddle, dunno how it handles gnar yet. Slacker than my v2 scandal but not as slack as my fs, just what I was after.
Im getting a bit of rattling over bumps, wondering if its cables inside the frame, everything else seems tight, anyone else suffer from this?
Used a boostinator to fit my old 135mm rear wheel, seems to be working ok, will need to sort something else out coz the ageing crest on there prob wont put up with the punishment I'll end up putting it thru. Ive already tweaked saddle position, bars felt right from the off, may have a play around with them tho.
*Had a hard time during build, everything that could go wrong did, but weirdest was when I fit the rear hub while I fitted the chain, later I went to remove the wheel again, realised it was 8mm, but the only 8mm allen key I have is in my camelbak, which was still the cupboard, so how the hell did I fit it?
Posted : 26/05/2020 11:36 am
Finished building my Scandal up this weekend, and just completed my third ride on it.
Very, very pleased with it.
It's a mix of shed parts and components from a donor bike, oh plus I nicked the 27.5 Plus wheels off my Focus Jam2, until the 29er back wheel arrives.
I'm loving the geometry very confidence inspiring, particularly with the Monster Truck tyres.
It weighs a reasonable 30Lbs with the big tyres, so should come in Sub 30lbs with the 29er wheels and 2.4 tyres.ON ONE SCANDAL-1ON ONE SCANDAL 2ON ONE SCANDAL 3ON ONE SCANDAL 4ON ONE SCANDAL 5
Posted : 26/05/2020 12:16 pm
I seem to have messed up posting the pics!!
Any tips on how to do it?
I'm on a MacBook - Cheers
Posted : 26/05/2020 12:17 pm
 D0NK
click img button and paste the address of the image, click "ok", hit return click img again for pic 2, etc
afaik the forum doesnt host pics itself.
Posted : 26/05/2020 12:27 pm
ON ONE SCANDAL 1
Posted : 26/05/2020 12:32 pm
ON ONE SCANDAL 1
Posted : 26/05/2020 12:36 pm
 D0NK
looks like you're using https://www.flickr.com/cameraroll/ as the IMG link which isnt sufficient, you need the address of the picture itself
Posted : 26/05/2020 12:44 pm
Thanks DONK.
ON ONE SCANDAL 1
Posted : 26/05/2020 12:45 pm
I use this to post pictures
https://postimages.org/
Upload and copy the img hotlink for forums link. Then just paste it
Posted : 26/05/2020 12:52 pm
Finally figured it out!!!
Here are the rest of the photos.
You can see from one of the shots that even with a Maxxis Minion DHR II 2.8, there's still loads of clearance.
I had some of the issues mentioned on here during the build:
Yes. I dropped one of the little screws from the top cable guide into the frame the instant I unscrewed it!
Had to take the forks off to get the screw out through the head tube!
Also wrestled with the cable routing a bit, but found some good tips on here.
Thanks guys!
ON ONE SCANDAL 2
ON ONE SCANDAL 3
ON ONE SCANDAL 4
ON ONE SCANDAL 5
Posted : 26/05/2020 12:54 pm
[url= https://i.ibb.co/YRT5Wpk/oneone2.pn g" target="_blank">https://i.ibb.co/YRT5Wpk/oneone2.pn g"/> [/img][/url]
[url= https://i.ibb.co/PgbdJ9W/Onone.pn g" target="_blank">https://i.ibb.co/PgbdJ9W/Onone.pn g"/> [/img][/url]
[url= https://i.ibb.co/31yjH5r/onone3.pn g" target="_blank">https://i.ibb.co/31yjH5r/onone3.pn g"/> [/img][/url]
Just waiting for a part so I can fit my dropper. It's a superb bike!
Posted : 26/05/2020 12:55 pm
Some of these look really good, especially the orange ones.
Not sure why there's a chainstay protector on that singlespeed one though?
The dropper post hose routing under the BB shell and into the rear of the seat-tube......why don't other companies do this? It looks much tidier than from the top of the down-tube to the front of the seat-tube.
Posted : 26/05/2020 2:11 pm
@thisisnotaspoon
I havent looked, but have you looked at Shimano Hubs? The new Deore can be had boost, microspline etc and even have cartridge bearings. Can't be that expensive...?
Posted : 26/05/2020 2:22 pm
 D0NK
Not sure why there’s a chainstay protector on that singlespeed one though?
My SS has one, doesnt take much chain wear/stretch and it'll bounce against the stay and its something I do with all my bikes at build time. Was considering trying mine SS, then I remembered the cables run through the bloody frame, grrr.
The dropper post hose routing under the BB shell and into the rear of the seat-tube……why don’t other companies do this?
Concern about rockstrikes on the BB spannering your dropper hose? it's something I worried about when I saw it, maybe unfounded? dunno.
Posted : 26/05/2020 2:34 pm
I havent looked, but have you looked at Shimano Hubs? The new Deore can be had boost, microspline etc and even have cartridge bearings. Can’t be that expensive…?
The XT rear is £90, which whilst not bad, isn't cheap anymore. And the new cartridge bearing MT401 seems to be vaporware at the moment. I was kinda hoping someone would have one for review and I could see what the freehub mechanism was like first.
I don't mind paying Hope / DT350 money when they're on a bit of a sale as they'll last forever. And I don't mind cheap hubs that can be replaced for not much more than the bearings cost, it's the the inbetween stuff I can't justify.
Posted : 26/05/2020 3:27 pm
I had a Pitch with brake hose routed under there and it never caused a problem despite a couple of dinks in the frame befor ei got round to making a protector.
Posted : 26/05/2020 3:30 pm
Are those tyres pretty heavy? I have 2.8 Nobby Nics on mine, with a build that looks similar to yours and mine weighs 28.4 pounds.
The pics make it look a ridiculously slack frame, especially in orange for some reason.
Posted : 26/05/2020 4:01 pm
Mine has rigid fork(and currently 2.1) tyres which are getting changed to something fatter which will up the weight. 23.5lbs
Posted : 26/05/2020 4:16 pm
Mines (almost) original stock GX build but with GOMA tyres, Brand-x dropper and a carbon SLR saddle (I love my parts bin, it reminds me of when I actually had spare cash).
Think it was a gnats chuff under 29lb on my bathroom scales.
Haven't decided if it feels that heavy or not. I've been riding the gravel bike to much recently so the upright position combined with heavy-ish tyres probably makes it feel heavier than it is!
Posted : 26/05/2020 4:34 pm
Yeah, hamishthecat its a bit of a Tonka Toy build. The Maxxis Minion 2.8s are approx 1020g (2.25lbs) each, so pretty hefty.
The whole wheel set is hefty though - they are off my ebike.
I've got some 29" Goma 2.4s to put on the Scandal when the new rear wheel arrives.
In Nov 18, I bough a Focus Jam2 emtb.
I'd been riding mountain bikes for 30 years and wasn't really thinking of an emtb until I tried one out whilst on holiday in the Taygetos Mountains in Greece.
Anyway that was a revelation and I had to have one.
BUT, I didn't want to stop riding normal bikes, but when I bought the Focus I realised that so much had changed in bike design since my last new bike (Santa Cruz Chameleon 2012).
I've got a few regular bikes but all are 26ers with QR forks - old school, and the type of riding that the Focus now allowed me to do just didn't feel the same on the old style bikes.
Both my Chameleon and SC Heckler now felt too short and steep, with flexy forks!!
I'd never had 27.5 wheels, bolt through axles, dropper post, tubeless tyres, modern slack geometry etc., etc.
To get all of that in one go was pretty intoxicating.
Plus all the extra fun the power assistance gives you.
But as I've said I'm still keen on riding regular bikes, so my aim in building this Scandal up is really to create a bike that has similar geo, fit etc., to my Focus and offers similar poise and a confidence building ride - just without the Shimano motor!
The rides that I've done so far totally confirm this.
Drop the post and point in down a steep rough chute and it's a blast, AND it climbs up stuff much, much better than I was expecting - Love it.
I think I'll be spending a fair bit of time of this one, and it's going to be a pretty fantastic winter bike too.
Posted : 26/05/2020 5:30 pm
Hi all, some advice please.
Working through my build at a (seemingly) glacial pace and tried fitting the drivetrain tonight.
Here's the clearance between the crank and chainstay...
null
Seems a bit tight, no?
Posted : 26/05/2020 11:31 pm
*Slippers model's own.
Posted : 26/05/2020 11:39 pm
Think thats normal.
Posted : 27/05/2020 12:16 am
Page 18 / 28
