The Most Boring Bit...
[Closed] The Most Boring Bit of a Bike
[#3810137]
What is the most boring bit on a mountain bike?
I just can't get excited about seat posts, or bottom brackets.
What's the most boring bit of your bike?
Posted : 26/03/2012 3:40 pm
headset spacers.
headset spacers.
you can get carbon ones man
the bolt that connects the seat to the seatpost would be my suggestion
Posted : 26/03/2012 3:42 pm
Gear cable end crimps
Posted : 26/03/2012 3:43 pm
Also the most exciting bit if it suddenly goes missing 😉
those little metal shrouds you crimp onto the end of your gear cables, they're pretty dull
Bolts don't count! 😉
The rider when they start banging on about how much weight they saved by fitting ti bolts everywhere... Who cares.
Posted : 26/03/2012 3:44 pm
All the bits are pretty boring in isolation. It's when you stick em together that they become interesting! 🙂
Posted : 26/03/2012 3:45 pm
Inner tubes. That's why I ride without them. 8)
Posted : 26/03/2012 3:47 pm
quite an amazing thing the bicycle, lots of simple bits working in harmony to furnish the user with fun and transportation.
so none of it
Posted : 26/03/2012 3:51 pm
BLASPHEMY! nothing is boring on a bike.
Posted : 26/03/2012 3:52 pm
[i]nothing is boring on a bike. [/i]
But some of the riders are.
Posted : 26/03/2012 3:53 pm
Just looking at the pictures of my bikes on the computer and I can confirm that no part of any of them is boring.
Scrutinised the brake adaptors, ferrules, spacers, nipples etc but no I find it all amazingly interesting.
Seatposts and BBs are off the scale
Posted : 26/03/2012 3:54 pm
headset spacers, cable end crimps, bolts, even the humble aportace spring...all serve a purpose. Valve caps, on the other hand, do not. BURN THEM.
Reflectors that never make it past shop door on new bikes that never knowingly end up on the road
Posted : 26/03/2012 3:56 pm
X2 for reflectors. On most serious MTB's they will be taken off and end up in landfill. Also the ones that come on new Shimano SPD's. Doesn't go with the green transport message.
Posted : 26/03/2012 4:01 pm
Serial number on the forks.
I have Merlin remove mine before delivery.
Is Merlin your butler?
Posted : 26/03/2012 4:04 pm
The little nut which holds the valve stem in place, I thought they were boring when I didn't need them, now I do (ust) they are even worse! 🙁
Nipples
Posted : 26/03/2012 4:07 pm
the bearings on a full suss, no bling or excitement to be had..
Posted : 26/03/2012 4:08 pm
Just me who actually enjoys crimping cable ends then...
Posted : 26/03/2012 4:18 pm
once saw a 6 page seatpost grouptest in mbr.
WOW
Posted : 26/03/2012 4:19 pm
They do, I lost all the air in my shock once because it didnt have a valve cap and some gritty mud got in there and somehow opened the valve.
Fantastic when you need to pump up a tube from flat the valve doesnt disappear inside when connecting the pump.
Ceramic bearings!
Posted : 26/03/2012 4:20 pm
[i]They do, I lost all the air in my shock once because it didnt have a valve cap and some gritty mud got in there and somehow opened the valve.[/i]
Just screw the valve tight when you've finished with the pump!
Posted : 26/03/2012 4:23 pm
but they come in pretty colours too!
Posted : 26/03/2012 4:30 pm
Cant really do that with the schrader valves they put on shocks can you.
Posted : 26/03/2012 4:37 pm
[i]Cant really do that with the schrader valves they put on shocks can you. [/i]
non-wheel valves. Odd, but good call.
Posted : 26/03/2012 4:39 pm
The Rider.
Posted : 26/03/2012 4:49 pm
verses - Member
No, me too, because that usually signifies the build is done and bike is ready. 🙂
Posted : 26/03/2012 4:50 pm
No, me also
Posted : 26/03/2012 4:51 pm
aportace spring
Posted : 26/03/2012 4:58 pm
headset spacers.
Even more exciting, the Mt Zoom carbon ones have little cut out sections, so thinner, lighter walls for most of it and three 'fatter' bits to allow them to sit properly 😀
Posted : 26/03/2012 5:09 pm
I reckon brakes are boring due to the fact that they make you slow down. 8)
Posted : 26/03/2012 5:14 pm
Gotta be the star nut thing in the steerer tube shirley? You don't see it, it just does it's job and I don't think you can get bling-y one's (waits to be corrected) ... but I also like putting crimps on the cables, the last thing I do when I build a bike up and it means it's time to ride it!
Posted : 26/03/2012 5:39 pm
Disagree, I love replacing mine with the best quality bearings I can source then feeling how smooth they are. Usually SKF bearings..
I would have agreed with the star nut but then noticed the quality of the one which came with my Chris King headset, also got the Hope Head doctor which is engineered alloy..
Mud guards are boring if you use them, or I would agree with the cable crimps. Also to consider would be the oil on the chain..
Posted : 26/03/2012 5:42 pm
Cable guides. Or stems.
Posted : 26/03/2012 6:03 pm
If bolts dont count...
Brake caliper mounts
Inner tubes
Steel springs
Cable ends, and the little bits that go on the end of outers.
All the little seals/o-rings on anything hydraulic
Cant think of any more.
Posted : 26/03/2012 6:06 pm
if the cable ends are crimped just once, they are boring.
However, if they are crimped twice, then beauty occurs.
+1 for brake caliper mounts, although Hope ones are nice.
Posted : 26/03/2012 7:09 pm
Star nuts are even more pointless because once the stem bolts are done up they don't do anything at all!
Posted : 26/03/2012 7:34 pm
 gazc
relentless fine tuning... yawn
Posted : 26/03/2012 7:37 pm
Mine have got little valve core-removing forks on top, very interesting.
Posted : 26/03/2012 7:42 pm
I used to think fork steerers were boring until...
Rachel
Posted : 26/03/2012 8:16 pm
'until Rachel'?? I have just about got the hang of gnar, huck and 'all mountain' but what does Rachel mean in terms of 'biking'? (dude)
Posted : 26/03/2012 8:49 pm
