The "I've bought an...
[Closed] The "I've bought another tool I'll hardly use but will still be handy" thread.
[#9930631]
After recently buying a mech hanger checker/alignment tool, which has already proven handy....I've now invested £11 in a star fangled nut setter.
Yes, it can absolutely be bodged. Yes, I'm sure many people bodge fit them on a regular basis and always get them 100% level in the steerer but not me. It's also a job I don't like doing on new forks. Not "cut the steerer" bad but not enjoyable even so.
It's reassuringly all made off steel (apart from the small 1" shim...which I will probably never use, ever) and rather cleverly made inside to make it pretty much impossible to seat the nut askew. Though I'll give it a try no doubt.... It also won't drive the nut down further than 15mm max.
So I give you the "tool I won't use very often but glad I have it" star fangled nut setter!
[url= https://s20.postimg.org/r0at5p97x/IMG_20180407_033106.jp g" target="_blank">https://s20.postimg.org/r0at5p97x/IMG_20180407_033106.jp g"/> [/img][/url]
Posted : 07/04/2018 5:17 am
Think all my bikes have head doctors.
Posted : 07/04/2018 6:08 am
Head doctor here too.
Posted : 07/04/2018 7:53 am
Yesterday I used my Octalink Crank arm extractor.
I think this is the second time I have used it in 6 years, the last time being when I installed the BB that was replaced yesterday.
However in that time it’s been on loan several times so worth having these tools.
Posted : 07/04/2018 8:02 am
I’ve got a whole box full of tools I barely use.
Posted : 07/04/2018 8:12 am
Its a great tool.
Straight perfect depth with one blow of a hammer.
Posted : 07/04/2018 8:21 am
I've been married quite some time.... I have a tool that will get used very rarely!!
Posted : 07/04/2018 8:22 am
I got the Park Tool star nut setter a few years back. I have used it a grand total of once so far.
Posted : 07/04/2018 10:35 am
Circlip pliers, with a range of interchangeable ends, sprung out, sprung in, curverd, etc.
Only needed once in a blue moon, but invaluable when you do.
Posted : 07/04/2018 10:47 am
Hayes Brake Pad and Rotor Alignment tool. Only needed twice in 5 years but a pleasure to use.
Posted : 07/04/2018 11:13 am
Bought a SFN tool a decade ago and it's had much use, £10 very well spent.
Best recent purchase was an impact driver, prompted by a jammed bolt on a shock. I didn't think it was gonna do it... but then it did.
Expect to have to use it once a year or less, and still see it as very good value.
Posted : 07/04/2018 11:17 am
Hope hub bearing tools for me recently. I know it can be done with sockets but no point changing bearings then screwing up the seals with a bodged tool. Justified it as I’ve three sets of wheels.
Posted : 07/04/2018 11:18 am
I have one of them. Had it for years been used loads of times.
Latest additions are digital calipers, big adjustable spanner with a hammer head on it and a Park wall mounted stand that has been attached to a folding tv wall stand so it folds out of the way.
Posted : 07/04/2018 11:36 am
I bought a star nut setter years ago and forgot I had it... had cut down some forks and fitted the nut with a bolt and hammer... then saw it in a drawer later. Duh.
Recently bought a BBB pressfit Bottom bracket kit after bodging my last one. As I’ve only 1 bike with pressfit, better stick to Race Face bbs or I’ll never get to use it!
Posted : 07/04/2018 11:39 am
I got a lovely set of headset spanners and a garage full of bikes with press fit headsets.
I might have a shock bushing tool somewhere as well - I've not had a full suss for about 4 years.
Posted : 07/04/2018 11:48 am
About 6 months ago, a treated myself to a set of about 12 frame bearing tools. Cost about £200 and never been used.
Posted : 07/04/2018 11:53 am
Same here with the shock bushing tool. Used once and has Sat in the toolbox for the last few years. Should probably get another full-sus bike soon just to make use of that tool...
Posted : 07/04/2018 11:55 am
Bore cap removal tool for Hope brakes bought recently as on offer.....mine have been v reliable and I used the hope service for a rebuild once in 12 year.
But it was cheap and I need to replace my son's rubbish avids and second-hand prices for working hope sets are high.
Posted : 07/04/2018 12:01 pm
Some years ago I bought an original Klein MC headset tool kit just in case. After 23 years I don't see the original headset in my Klein Attitude ever needing to be replaced!
Posted : 07/04/2018 12:35 pm
I’ve used my star nut setter loads. Having been brought up in a house with a dearth of proper tools I take pleasure in getting the right tool for the job at every opportunity. Worst vfm is a 32mm fork seal setter which I got from Real World Cycling in the states along with various other blinged up anodised stuff. Works superbly but used once in 15 years.
Posted : 07/04/2018 12:44 pm
<div>molgrips
<div>
<div>Subscriber</div>
</div>
</div>
<div>
</div>
Admittedly it was years back now but never got on with mine. Couldn't get it to bind on the inner part of the steerer most of the time and ended up just using the top cap for bling value.
Posted : 07/04/2018 2:46 pm
Bought a new tool cabinet to help sort out my bike tools - I have at least nine bottom bracket tool of varying types, a couple that have been used just once to remove an old unit and replaced with something else. 10 if you include the 18" Stilsons!
Posted : 07/04/2018 10:07 pm
M5 tap. Used it once per bike, so a total of three times on bikes
It was very useful to sort a toilet seat hinge that kept coming loose though
Posted : 08/04/2018 8:36 am
Got this coming, second hand. Again, won't use often but will be good to see if there is a "rogue" spoke on the wheel sets. 😃
Posted : 11/04/2018 10:52 pm
How about French bottom bracket chasing and facing tools..! Not cheap either.
Posted : 11/04/2018 11:52 pm
 Gunz
Headset press.  So nice not to have to use a hammer and blocks of wood anymore.
Posted : 12/04/2018 3:15 am
Thanks to bigyan I've just ordered these circlip pliers for impending fork servicing duties.
Screwfix down from £15 to £4 (collection in store).
Posted : 12/04/2018 4:53 am
 goby
Tv wall mount with park tool head got any pics Tracey?
Posted : 12/04/2018 8:27 am
 CHB
Of all the bike branded tools I own, this one gets by FAR the most use:
Posted : 12/04/2018 8:32 am
Bought the longest I could get off Ebay that said it could hold a TV far in excess of the bikes weight. Works a treat, folds flat against the wall when not in use so that I can get the car in
Posted : 12/04/2018 9:29 am
 goby
Thanks Tracey, ah off to eBay we go!
Posted : 12/04/2018 9:57 am
 colp
You were doing so well then you went and ruined it.
Garages are not for cars, except when getting insurance quotes of course.
Posted : 12/04/2018 10:04 am
I bought one with the largest wall mount I could find to spread the load, its held in with 8 big bolts and also bonded. Paid £19.99 for the bracket but cant find the same one when I click on it
Posted : 12/04/2018 10:06 am
Loads of room for the car and everything else in the garage. Its one of the many obstacles you would need to maneuver to get to the bikes.
Posted : 12/04/2018 10:10 am
Love the TV stand hack - want one 🙂
Here's four inexpensive things that I wouldn't be without:
Left to right:
1. Box of universal stainless allen bolts. I've got another couple of boxes of different lengths, and heads and it's astonishing how useful they are
2. Brake piston lever, although it's often just used as a generic lever whenever something needs some delicate adjustment and I can't reach my hammer
3. Fox lower leg removal tool - really useful thing, although I managed without it for years, so it's hardly essential
4. Homemade, unchamfered socket for removing the top of Fox forks. Worth its weight in gold when servicing forks.
Posted : 12/04/2018 10:53 am
3. Fox lower leg removal tool – really useful thing, although I managed without it for years, so it’s hardly essential
You didn't?! You didn't actually [i]buy[/i] one of those for £30?! Thread winner if you did 😀
Posted : 12/04/2018 10:59 am
You didn’t?! You didn’t actually <em class="bbcode-em">buy one of those for £30?! Thread winner if you did
I'm afraid I did. I have a garage full of Fox forks and after using various ghetto solutions for years, I decided that the time had come to do it right and stop bashing various combinations of random garage metalwork.
I picked it up in the Mojo fire sale though, so paid a little less. This didn't make it hurt any less though
I've also got a Hope freehub seal tool, which is another thing that I think might be nearly unique 🙂
Posted : 12/04/2018 11:08 am
MG Midget 1500 clutch alignment tool.  Ods of ever being used again, incredibly slim, I suspect the world will run out of petrol before I wear the clutch out!
Posted : 12/04/2018 1:26 pm
Bought a cheap XT bottom bracket recently (before that thread) then found I had lost my Park BB tool that the adapter would have fitted into, so I bought the BBT-69.2 which should have fitted the adapter and so been useful for two sizes, but it wouldn't fit, so I bought the BBT-59.2 to fit exactly, and the 49.2 as it made the complete set 🙂
So cheap BB results in expensive tools...
Posted : 12/04/2018 2:06 pm
I just bought the Hope 30mm BB spanner. I intend to only use it once, when the BB arrives.
Posted : 12/04/2018 2:34 pm
I've just been trying out a few joints with my new "handy" Festool Domino. With all the trimmings.
It's a thing of beauty, and part of my recent drive to elevate the quality (even further!) of my furniture making.
Fortunately, I got a £75 voucher from Festool while i was trying to "justify" it.  So I only had to contribute the remaining £770.
Posted : 12/04/2018 3:55 pm
I don't like to be the bearer of bad news, but I have this (or, at least, a variant of it) and it sucks. It chews up outer BB shells and leaves them in a right mess. After the last one I did, I swore I'd never use it again and replaced it with a socket-based tool which is better in nearly every way.
Perhaps you'll have better luck than me, but IMHO this tool isn't the finest thing Hope have ever made.
Posted : 12/04/2018 4:18 pm
 Pyro
I bought a second-hand Race Face BB92 puller tool. Admittedly I still had to partially destroy the GXP Pressfit BB in a second-hand frame to get the chip in and lined up, but it worked lovely once I had.
I only have one other frame with a press-fit, and they're both getting Token screw-together ones, so I may never have to use this ever again...
Posted : 12/04/2018 4:30 pm
These two - makes shortening a brake hose a treat.
Posted : 12/04/2018 4:56 pm
I don’t like to be the bearer of bad news, but I have this (or, at least, a variant of it) and it sucks. It chews up outer BB shells and leaves them in a right mess. After the last one I did, I swore I’d never use it again and replaced it with a socket-based tool which is better in nearly every way.
Perhaps you’ll have better luck than me, but IMHO this tool isn’t the finest thing Hope have ever made.
What socket tool did you find for a Hope 30mm BB? I could only find the Hope sheet metal one.
