Decided to check freehub as I know the mavic ones need a bit of lube now & again.
Did it in the living room (watching lego masters Australia with kids)
And one of the springs is just gone, found the pawl but spring....
Now I've gotta pay £15 for a teeny spring
Anyone know if hope bulb ones fit?
SPRING DIMENSIONS: 5MM LONG (1.85MM COMPRESSED), 3.25 OUTER DIAMETER, .35MM WIRE
Under the sofa.
Like kayak23 said, under the sofa. More likely it’s bounced under the sofa, then bounced 15 more times & ended up under the fridge in the utility.
It’s called ‘fridge suck’. Like chain suck only more annoying.
Chop a bit of spring out of a clicky pen
I've got some Hope ones here if you want. PM me.
sourcing map Compressed Spring,0.12 Inch OD, 0.01 Inch Wire Size, 0.08 Inch Compressed Length, 0.2 Inch Free Length,2.6N Load Capacity,Gray,10pcs https://www.amazon.co.uk/dp/B08LD1K54K/ref=cm_sw_r_cp_api_glt_i_C1AF99CAHM1BPMYCZVXW?_encoding=UTF8&psc=1
ask me how I know this…
Thanks for the offer ambrose
Jambo you're amazing!
Are they magnetic? I have a couple of magnetic 'sticks' in the shed for finding all of the things that fly around in there.
Yup I've got the big magnet out, no joy
Have you got a tap and die set? I found a rear suspension spacer that I lost a couple of bikes ago inside the case. I spent hours searching the shed for it at the time... it'll be the first place I look for anything that goes missing from now on 😛
Found it!
On the bookshelf about 2metres from where I was sitting
Bravo!
Nothing adds value to an item more than finding it again after it's been lost.
Found it!
I bet that was the last place you looked as well?
Typical...
Found it!
Was it in correct ISBN order?
