That Zee mech with ...
[Closed] That Zee mech with Sram shifter combination??
 st
[#5626788]
Is Anyone here successfully running a Zee 10 speed rear much with a SRAM 9 speed shifter?
I bought a short cage mesh to replace my knackered SRAM X9 to run on an 11-28 9 speed cassette but can't get it working right. I' made a 6mm spacer (the cable sits slightly less than this in a groove I've filed into the spacer).
It's mostly working on the way up the cassette with just a couple of hang ups but not so well coming back down.
Should,d I expect it to work just fine or is it a bit of a compromise / fudge that you have to live with?
I've also tried it without the spacer as some threads on line suggest but that was a mess.
Ta.
Posted : 22/10/2013 9:38 pm
Mines fine. You must be a thicko.
Posted : 22/10/2013 9:49 pm
 st
Clearly
Tnuc...
Posted : 22/10/2013 9:51 pm
I got mine shifting perfect both down and up using an x7 shifter and a 11-32 cassette. I do not use a spacer.
All I had to do was play around with the limit screws
Posted : 22/10/2013 9:58 pm
Mine's perfect up and down same Zee/X9 with a spacer. Check your cable.
Posted : 22/10/2013 10:46 pm
Yeah, something wrong, if it works one way but not the other I'd suspect cable too. I've got 3 of these set up, and one proper 10-speed bike, they work much the same.
Posted : 23/10/2013 9:22 am
Works spot on with my X9 shifter and saint mech with spacer.
Posted : 23/10/2013 12:45 pm
