TFtuned lower lube ...
[Closed] TFtuned lower lube mix Vs Rock oil 15wt
[#2959605]
Will i notice a discernible difference using the former over the latter in my Lyriks?
Posted : 19/07/2011 10:41 am
I've got Automatic gear oil in mine and its really nice.
Posted : 19/07/2011 10:44 am
thats just thick oil isn't it?
Do they have foam rings or just oil seals?
Posted : 19/07/2011 10:46 am
if its 15 wt I'm guessings its for your lower leg lube in which case I can't see it making the slightest differene what it is?!
Posted : 19/07/2011 10:48 am
think the title suggests its for the lowers also 😉
Posted : 19/07/2011 11:32 am
I used to use it, now use fully synth engine oil. A lot cheaper, no noticeable change in performance or oil condition.
Sometimes I put a small amount of Fox Float Fluid (the really thick 85wt stuff) on the seals and inside the air chamber. This does make a small difference you can feel in the garage, can't say I've noticed it when riding though.
Posted : 19/07/2011 12:04 pm
I use engine oil in my Rockshox ,it works fine
Posted : 19/07/2011 12:12 pm
