tell me about the v...
[Closed] tell me about the various rear axle setups
[#1645523]
I currently run a standard QR on the rear wheel (135mm OLN on a 456 frame) but I need a new rear wheel.
What options are there? - standard QR, 12mmm, bolt-up, 15mm, etc.
What hub-type will fit a standard 135mm dropout and what QR would I need?
thanks
Posted : 26/05/2010 3:13 pm
If you're running a standard QR 135mm hub now then you'll either need another of similar spec, or you could also try a bolt-up/through 10mm 135mm hub, don't think any of the other standards will fit your frame.
Posted : 26/05/2010 9:21 pm
I wouldn't bother with anything weird - It's just a pain in the arse if you need to swap/borrow/replace/find
Posted : 26/05/2010 9:55 pm
