Tektro Novela rubbi...
[Closed] Tektro Novela rubbing
[#5256165]
I've been helping set up a bike a friend bought and can't get the front rotor to stop rubbing. Is there any way to get the pads further apart? The problem is that the only way I can get the rotor to not rub is to detach the cable completely but if I re-fasten at this level, the lever can go right to the bar and not lock the wheel. I've read their tech docs but totally stumped.
Posted : 18/06/2013 7:09 am
Both my son and daughter run these brakes.
I've not had major issues so maybe this is too obvious / something you've tried but when I changed the tyres on my son's bike and when my daughter's was first delivered there was a small amount of rub. I just released the qr and adjusted things that way, moving the wheel fractionally one way or the other and all was fine after that. This has been on a front wheel and rear wheel respectively.
This might be too obvious, as I mentioned, but hope you get it sorted. They've been decent enough brakes for basic cable ones imho.
Posted : 18/06/2013 8:07 am
Only the inboard pad is adjustable. I wound it out a bit, loosened the caliper bolts and retighhtened with the lever held to try and recentre the caliper, then wound out the inboard pad a bit.
Posted : 18/06/2013 8:28 am
I should learn my lesson. Never, ever, maintain someone elses bikes.
Posted : 18/06/2013 9:59 am
