Tektro Gemini 4-pot...
Tektro Gemini 4-pots
[#13394583]
Mrs_oab's crash at the weekend was down to a failing Altus  level disc brake... Her brakes are old and struggling, even a good bleed and fresh pads isn't great for power for some reason.
Silly cheap at the moment.
Are they any good? Google shows a few folk positive as long as you're not riding Megavalanche and / or weight 18 stone...
Use will be an 8st gentle, smooth rider, who occasionally wanders down red route level trails while alternating between squeals of delight and fear....
Posted : 23/09/2024 1:04 pm
Reeksy1 runs these on his Polygon and they seem good enough for his 55kg racing enduro.
Posted : 23/09/2024 1:08 pm
Matt, see what Magura MT5’s are these days. Beware though you really need to hold on when you hit the brakes, they are very powerful. Loads of modulation though.
Or these…
2 pot 4 pot combo MT Trail
https://amzn.eu/d/hCyNNVC
Posted : 23/09/2024 1:12 pm
 a11y
Also from the Tektro stable, these would be a worthy replacement: TRP Slate EVO
I bought a set for my trail bike early this year when Merlin had them cheap. Bought a second set for my Geometron and they're stopping my 90kg+ well. Nice lever feel, more progressive than Shimanos that I had before. I bought from that link/seller on eBay above, around £100 all-in for the pair. Ideally you'd want the 2.3mm rotors but they'll work OK with something more common like 2mm thick SRAM or Magura rotors. Unsure about standard Shimano 1.8mm rotor compatability but there was a thread on here about Slate EVOs I think.
2024-09-15 Geometron G1 first build 00016
Posted : 23/09/2024 2:13 pm
edge85, trail_rat, nicholas_yiu and 3 people reacted
Daughter has the Tektro Orion 4pot on her DH bike.
Seem to work well, only issue I had was bleeding - had to cut down a bleed block to slightly over-fill to get a decent lever feel.
Posted : 23/09/2024 2:23 pm
They are good, very good in fact. I fitted some to my Stooge as a stop-gap, and have just left them on.
Basically a cheaper version of the TRP Slate Evos I have on another bike.
Issues on the set I had from Merlin:
- hoses were set up Euro style so needed swapping.
- front hose was too short, so needed swapping out for a longer hose and bleeding.
- levers are old style clamps, so annoying to change.
Posted : 23/09/2024 2:27 pm
Andy_Sweet, matt_outandabout, Andy_Sweet and 1 people reacted
– hoses were set up Euro style so needed swapping.
– front hose was too short, so needed swapping out for a longer hose and bleeding.
– levers are old style clamps, so annoying to change.
I can cope with them, apart from front hose length. Thankfully mrs_oab is on skinny bars, low stack and 120mm forks so they may work.
[s]I agree the Maguras would be nicer - but they are £90 vs £50+cashback...hmmm[/s]
Edit: those Magura's have a lead time in months. What dodgy place is selling them?
Posted : 23/09/2024 5:35 pm
swanny853 and swanny853 reacted
Ideally you’d want the 2.3mm rotors but they’ll work OK with something more common like 2mm thick SRAM or Magura rotors.
They are £65 with Magura rotors included 🙂
Posted : 23/09/2024 5:45 pm
 a11y
Cos Mrs MOAAB is worth it! 😉
Edit: TBF that's a brilliant price, especially including rotors.
Posted : 23/09/2024 5:55 pm
Yeah didn’t spot the 3-7 months delivery. Glad I’m not drunk with a twitchy trigger finger.
Posted : 23/09/2024 6:46 pm
Tektro's ordered.
I'll update when they are on and working.
Posted : 23/09/2024 7:47 pm
Ah slightly too late but I wouldn’t recommend them. They use a tektro specific bleed kit, by the time I’d bought that and the £30 replacement hose they were no longer quite so cheap.
They also don’t come with mounting adapters thought you maybe already have those.
the adapters I have mean the caliper sits slightly proud of the rotor meaning not all the pad is engaging it. The feel isn’t great, they’re  a lot weedier than 2 pot SLXs and despite bleeding three time I still have air somewhere in the line.
Posted : 23/09/2024 8:59 pm
That's why I have a cheap kit with a dozen different adaptors.
Posted : 23/09/2024 9:11 pm
Nope standard bleed kit from Amazon/eBay.
I used hose from an old, leaky calipered Shimano brakeset 🙂
They take all the same hoses, olive and fittings as Shimano brakes.
Mine did - though it came with 203mm Tektro discs, so the adaptors were for those.
I used 180mm discs, and had spare 180mm adaptors.
You have the wrong adaptors for your disc size then!
Totally disagree. They're as powerful as the TRP Slate Evos imo. Good modulation, and very comfy levers.
You need to bleed them properly! Top down method, with cup at the top and syringe at the bottom.
Posted : 23/09/2024 9:16 pm
Tried and tested system- upgrade your brakes, give Mrs MOAA your old ones, everyone wins.
Posted : 23/09/2024 10:02 pm
I too have a 'multitude of fittings' cheap bleed kit,
The bike has adaptors and I've got spare,
It's a tiny bike with narrow bars, low stack and short forks, and I've measured the front hose at 800mm...
Powah, we will see.
Mrs_oab tried my new MT5's and sons xt 4-pots this weekend. Both led to near OTB crashes in the car park... ?
Posted : 23/09/2024 10:36 pm
They're on.. Not bedded in yet, but pulling well. I'm impressed.
Usual putting them on process. Front attached, set up Euro. Rear caliper and lever disconnected. Swap cable over and trim them. My front cable was short, but with skinny bars, small headtube and short forks it was still too long.
They're neatly made, compact caliper, slightly chunky reservoir on the levers. Levers feel nice. Longer than Shimano but shorter than Magura. Nice dimples on the lever for grip.
Middling pull, and not the Shimano sharpness of bite, but they are stronger in bite than Magura. Should get them out on trail tomorrow so I will update in use thoughts.
PXL_20240927_181309770PXL_20240927_181408042PXL_20240927_191338087
Posted : 27/09/2024 10:38 pm
reeksy and reeksy reacted
PXL_20240927_181216633PXL_20240927_181221038PXL_20240927_181204459
Posted : 27/09/2024 10:39 pm
But late to offer advice but another review if anyone is interested:
They can on my Whyte 529. I find them entirely adequate, not exciting or remarkable, not grabby or sharp,  consistent, feel quite linear, not mega powerful but plenty to stop, not amazing feel but enough. Quite a boring brake really! The dimpled leavers are nice.  Seem quite heavy but I'd get another pair if in the market for good value stoppers.
Posted : 27/09/2024 10:48 pm
fruitbat and fruitbat reacted
I haven't yet found a cheap source for the 5mm thick pads.
Posted : 28/09/2024 3:04 pm
I haven’t yet found a cheap source for the 5mm thick pads.
You can use standard 4mm pads (they use sane as Trp slate, Saint, etc.)
Posted : 28/09/2024 6:04 pm
Ke?
Mine came with chunky boi Magura Storm rotors.
Posted : 28/09/2024 6:54 pm
@matt_outandabout - the brakes come fitted with 5mm rather than 4mm pads. I assume for longevity? The originals lasted for ages on mine!
Anyway, they are the same size as Saint, etc. pads, and 4mm works fine
Posted : 28/09/2024 7:04 pm
Indeed that's one of the reasons I bought them - I've two sets of pads still...
Posted : 28/09/2024 8:47 pm
They look great.
Posted : 28/09/2024 10:13 pm
I'll take that as a good thing for a brakes!
Posted : 29/09/2024 2:51 am
thols2, ThePinkster, matt_outandabout and 3 people reacted
Matt - Any update now they have bedded in?
Interested in a pair of these:
1. How are the bleed ports different from Shimano brakes? I have a basic Shimano Total Bleed Solutions (syringe, plastic tubing etc) with mineral oil, would this fit on for the set up initial bleed?
2. Do Shimano standard brake pads work fine with these calipers ?
Posted : 09/10/2024 10:58 pm
Mrs_oab has been unwell so no riding unfortunately.
I've ridden up and down street at they grab well and have more power than her old Acera / non group set level brakes before, and broadly on par with Deore 4 pots. I haven't tested to limits though.
I've not had to bleed, but I've a very cheap 'every brake' bleed kit and imagine things will fit. Bleed port is placed similarly to Shimano.
Posted : 10/10/2024 8:59 am
And yes, standard Shimano pad sizing.
Posted : 10/10/2024 9:01 am
 Tim
I've just picked up a set of these 'new' (e.g. someone took them off a new bike).
I picked them up for my hardtail which has some highly underpowered Clarks on it...but I'm tempted to chuck them on my ebike to replace the Guide R's which are impossible to bleed and suffer from sticking pistons.
I can't imagine they will work any worse than the guides?  I loathe SRAM brakes in general as the build quality is bobbins in my experience...
Posted : 18/01/2025 12:22 pm
doubleeagle, mezimov, doubleeagle and 1 people reacted
Not used Guide R’s but I’d broadly lump them with Deore 4 pots as above.
Winding the Levers out much further than usual resolved some of my issues with crappy lever feel. Some decent Galfer pads and they’re in the pretty good for cheap brake’s category
Posted : 18/01/2025 10:42 pm
