TdF bikes
[Closed] TdF bikes
[#727275]
What gear ratios do they run?
Posted : 22/07/2009 11:22 am
Typically 11-23 and 42/52 for normal days and 11-25 and 39/53 for hilly ones. Obviously some riders will have different preferences
Posted : 22/07/2009 11:25 am
sastre uses 38/52 Q-rings and 11-23 all the time. apparently
saying that Tyler hamilton and Floyd landis used 36/52 compacts in the mountains( as well as illegal Subs...)
Posted : 22/07/2009 11:28 am
Posted : 22/07/2009 11:29 am
lots of riders on 38-26/28 if on sram
contador is running 38-28
Posted : 22/07/2009 11:31 am
anyone use compacts or triples then? Even the big sprinters or fast cadencers?
Posted : 22/07/2009 11:33 am
No one on triples, a few use compacts on the hilly stages. A sprinter on a compact would be severely handicapped, you'd run out of gears!
A lot of them will likely run 11-21 blocks on the flat stages.
Posted : 22/07/2009 11:36 am
Triples (before compacts came out) and compacts have been used on silly steep climbs like the Angliru but not normally on other climbs.
Posted : 22/07/2009 11:37 am
Compacts have been used occasionally on some of the silly steep Pyrenees stuff but it's rare that the Tour visits such terrain. Most of the time a 38/39 inner and 52/53 outer. 11-23 cassette, maybe 11 (or 12)-25 in the Alps/Pyrenees.
As trev says, Sastre and a couple of others use those Rotor cranks with the Q-rings (oval chainrings similar to old Shimano Biopace).
Posted : 22/07/2009 12:02 pm
Similar in the sense neither is round? 🙄
Posted : 22/07/2009 12:06 pm
Well Q-rings are exactly the same theory, but done right, as they're rotated by 90 degrees compared to Biopace.
Most Alpine/Pyraneen climbs aren't that steep, if I can get up 20% (short) climbs round here on a 39/23 bottom gear I'm sure most of them have the legs to keep that turning for a long time on a shallower gradient!
Posted : 22/07/2009 12:10 pm
