Hi
Ive read somewhere that you can get adapters to fit a tapered steerer into a 1-1/8" straight headtubes (Tapered part stays out of the headtube). I also read that they are only for certain frames.
Anyone know of the Santa Cruz Heckler is a frame that can use these adapters?
[i]Tapered part stays out of the headtube[/i] 😯
you'd have about 6cm of steerer sticking out the headtube on my forks!
Well im not sure of the full set up and how it all works but its possible according to what i read. Cane Creek headset i think. Maybe its not the tapered part as i think thats fits but it wont fit with the bearings.
I think the head tube needs to have an ID of 44mm or more, so if the frame takes a normal 1 1/8th lower then you cannot fit tapered steerers. Of course someone may be along to correct me...
Jay
Sorry, but you need a 44mm headtube originally designed for an internal headset. With a standard 1 1/8" headtube designed for external cups, you can only run a straight 1 1/8" steerer.
thanks guys, should have known it wouldn't work, too good to be true! Ill keep looking for some straight steerer forks in the spec. Really should get the new Heckler frame with taper!!
ha ha love the idea...but i doubt ill be trying that!
I love the fact that someone's given their hammer a name.
Have a look at where the pic is from! World Champs!
Yep, young kids here too...
