Tanuki main(bottom)...
[Closed] Tanuki main(bottom) pivot?
[#4195248]
Hi,
Does anyone know what the main (bottom) pivot is comprised of, or what it should look like from the outside? I just got mine back from the shop and noticed there is a bolt head with hex socket on the non-chain side and I do not see anything on the chain side. Can anyone confirm there should be a similar bolt with hex socket on the chain side?
Posted : 25/07/2012 5:44 pm
im not sure which bit you mean? could you put up a picture then ile compare it with mine.
Posted : 26/07/2012 9:05 pm
