Tandem forks
[Closed] Tandem forks
[#3551170]
Hi All,
Just got an old Dawes 'Back street' tandem from Ebay. All good on our first ride, apart from the forks which seem a little weedy/flexy, given that they have to cope with nearly 400lbs of pure muscle* aboard.
As we are thinking of touring on it the all-up weight will be even greater, so should I replace the fork with something a bit stronger or just MTFU and accept the OE fork. (Headset is 1" BTW, so would probably have to get something made to order...)
Any suggestions?
*This might not be true.
Posted : 10/01/2012 10:28 pm
Dawes are generally well made so the OE fork should be enough. the two usual tandem shops I know of have nothing - sjs and JD cycles.
try the tandem club boards perhaps?
Posted : 10/01/2012 10:41 pm
Is it steel? You could get a 1.5" head tube welded on and get some proper forks on there! 😀
Posted : 10/01/2012 10:44 pm
There's a US forum, double forte at yahoo groups, you could try asking for advice there.
Posted : 10/01/2012 10:49 pm
It'll be fine. Sure it's the forks flexing not the wheels? Are they large flange hubs? 36 spokes or more?
Posted : 10/01/2012 10:52 pm
As above. I'd get the wheels re-tensioned and see if it feels a bit better then. Nowt wrong with a bit of spring in the fork!
Posted : 10/01/2012 11:00 pm
Thanks for the replies, everyone.
The frame is steel (Reynolds 501) and I did wonder about getting the head tube changed to 1 1/8 (or even 1.5!), but I suspect I could probably buy a more modern tandem from 'The Bay' for less money!
(I have read about 1" tandem forks snapping at the base of the steerer tube, hence my concern. I suppose on reflection I should have done my research BEFORE bidding!)
Posted : 10/01/2012 11:27 pm
Could be the wheels as they are 700c on what appear to be standard hubs...
Posted : 10/01/2012 11:30 pm
I have had 2 road bike tandems with skinny 1 inch forks and not had any problems
I have two Dawes tandems, one 531 Super Galaxy with a 1" steerer. Never had a problem. the other is a heavier generic steel. Flex of the forks is fine. It is steel after all. I suspect the wheels.
Posted : 10/01/2012 11:56 pm
