i,ve got a WI 130mm eccentric hub and a WI freewheel, i havn't brought the cranks yet cos i'm not too sure about chainline as the rear isn't adjustable the front will have to be, so i'm currently thinking square taper only as external of hollowtech won't be adjustable? am i right??
Sheldon Brown says: "White Industries ENO hubs use this chainline (47.5mm), which lines up with the middle position of a typical MTB triple.
It's also fairly close to the outer position of a typical "road" double. "
I may be wrong here, but depending on the BB shell width, Hollowtech II chainline should be adjustable to a certain degree (i.e. 2.5mm) with varying combinations of the black spacer rings, as each is 2.5mm.
