Talk to me about dr...
[Closed] Talk to me about dropper posts.
[#5204018]
I haven't bought any mags for years, last big MTB purchase was my Pitch pro at the beginning of 2010. And I love it.
Tried a cheap non remote dropper post and liked it, so I want to buy a remote one.
I need a 30.9mm one. The distance from my saddle rails to the seat clamp is 190mm and I can fit 19cm of seatpost into the seat tube before it hits the bend in the frame. I'd like one that drops as much as possible.
I want something that is reliable and works well - not bothered about the absolute cutting edge tech but I don't mind paying for quality - just save up more!! Parts and backup is very important to me.
Thanks in advance!!!
Posted : 30/05/2013 6:53 pm
Reverb.
/thread
Posted : 30/05/2013 6:54 pm
I kinda thought that... isn't there any others that come close?
Need help on size/length though.
Posted : 30/05/2013 6:55 pm
125mm drop 380mm post length
Posted : 30/05/2013 6:57 pm
Buy a reverb or a KS, they are both great, You need to check length and Od carefully. They are truly brilliant.
Posted : 30/05/2013 7:00 pm
 teef
I'd avoid KS at the moment - I've got one and am having problems with it. I took it back the LBS I bought it from and they told me KS don't currently have a UK distributor so the can't send it to anyone to be serviced.
Mate has just got a Reverb and reckons it's miles better than the KS he used to have.
Posted : 30/05/2013 7:09 pm
KS LEV or Reverb. LEV requires no bleed and real easy to set up...but no UK distributer if things go wrong.
Reverb equally good but bleeding can be a pain in the arse.
Having had both, I prefer the KS for lack of faff.
Posted : 30/05/2013 7:20 pm
To be a bit more helpful. I have a Reverb and it has been really good, I have sent it back twice and it has been replaced, so the back up has been great and I prefer the way it works to the KS.
A lot of the guys I ride with run KS's They are cheaper to buy, but as above they have no UK distributor ATM, this has never been been a problem as they have always serviced them themselves, without any problems.
Posted : 30/05/2013 7:24 pm
I've had a KS i950 for two years now and it it has been fine (2-3 rides a week). I take it apart for a clean and lube every two months or so. The only time it really acted up is when I neglected the regular service and there was a build up of dirt at the actuation arm at the top of the post. Still working as new. I only want a Lev because of the fixed cable anchor and the shielded actuation mechanism.
The only thing I don't like about the Reverb is actually the hydraulic actuation. Rip a hydraulic line in the middle of nowhere and you can't just rebleed the thing on the trail. With a KS (or the rest of them for that matter) it's just a regular shifter cable.
Posted : 30/05/2013 7:49 pm
I've recently bought a Reverb and have been really happy with it. I run the lever under the bar to give it some protection (I'm running a right hand lever under the left side of my bar). I was really worried about the hose when the post was dopped but I've not noticed it; I don't catch my heels on it and the tyre doesn't buzz it as the suspension compresses. Personally I'm not too fussed about the ink of pulling a hydraulic line out because I do t do wilderness epics so I'll never be that far away from civilisation.
I've ridden a Lev last week and it was pretty good. The fixed cable fitting was really good and I quite like the way the lever was integrated into the grip although I prefer being able to set it away from the grip like with my Reverb because it feels more natural to be. I don't know if it was just the one that I was using, but I didn't find that it dropped as quickly or as smoothly as my Reverb. The lack of distributor would put me off too.
Posted : 30/05/2013 8:29 pm
I'd consider a specialized command post, mine was excellent and at about 2 years old I'm reasonably sure it had never been serviced, still worked fine.
Lot cheaper than a reverb if you're looking 2nd hand, never used a reverb so can't comment on how much better they are, but the command post is certainly excellent in its own right.
Posted : 30/05/2013 8:53 pm
I've got 2 KS's, they're fine but yep temporary lack of distributor is a concern. Just as good as a reverb, though, and without the crazily expensive and harder to find spares.
Posted : 30/05/2013 9:07 pm
Have a Joplin 4 and been pretty happy with it. No issues and still going strong after two years.
Posted : 30/05/2013 9:12 pm
I'd never pay full price for a Rverb because I'm tight but they do seem to crop up in sales quite a lot. I picked mine up cheap from Wiggle...the cost of spares does scare me but hey ho.
Posted : 30/05/2013 9:25 pm
I was heading for a Reverb but I'll check out the KS ones too.
Posted : 31/05/2013 10:42 am
Had both, Reverb lever under the bars is miles better ergonomically, KS lever looks like a good idea but isn't - Reverb not having a cable makes it work better and more reliably.
Posted : 31/05/2013 10:50 am
Reverb.
/thread
Posted : 31/05/2013 10:52 am
Had a reverb for 18 months, and have now sent it off to SRAM for a service.
I miss it so much !!!!
It really improves the flow of a ride
On my ride on Sunday I was even pressing the handlebar where the remote should have been !
Posted : 31/05/2013 10:57 am
Running Specialized Command posts on all of our bikes with no problems.
Posted : 31/05/2013 11:13 am
