Assuming the same hub shells it probably is a better idea to buy a new hub and transplant axle/freehub body, then sell the old one!
That`s what i ended up doing njee20, piece from here, piece from there...
If AV had the stock in at the time i`d have benn laughing.... 😆
34t 42/10 here
lincolnshire/peaks
have an oval absolute black ring coming
sell the king, get a DT 240 hub
For all the sram users out there with the 1x11.. has anyone experienced the weird creaking from the rear mech? Have an 1XO rear mech and is only 100miles old?!
I have`nt had it happen yet, but it is an easy fix. the clutch is the problem and just requires a little grease, there are vids to show you how to do it..... 8)
I had an issue where the mech was clunking, was like a pivot on the swingarm of my tallboy was very warn - stripped down the clutch which resolved the issue
In terms of overall value then the Sram 1x11 setup seems outrageous price wise compared to Shimano 1x10?
Is it purely because they can brag more range of gear coverage?
More to do with the cost of producing the rear cassette, and that mugs (myself included) will pay though the nose for the latest thing. If anyone is interested, I have an as new (taken off a new bike before use) x1 shifter, cassette, mech and chain you can have for £300 (what I paid on here for it, not looking to profit, just that plans have changed) mail in profile. It's not that I don't like it, I do, it's brilliant and have it on 3 bikes, I was going to build a bike from frame only but then was made an offer I couldn't refuse on a full, 1x11, bike but had already bought the above kit.
[\shameless advert]
Well XX1 is cheaper than XX, and X01 is cheaper than X0, so it's not really a premium at all, it's just top end group sets.
The cost is driven by the construction of the cassette, but a 10 or 9 speed cassette produced the same way is comparable in price - check out the XG 999 or the XG 1099.
stoney - MemberI tried to get it all from Aspire, but they had ran out of stock, it would have been roughly $1k, (approx £600)& you take a chance on import tax, even then it`s till miles cheaper.....
Aspire more expensive than the German sites, and no risk of import tax from Germany
Tom YGM 🙂 cheers Stu
Possibly have actually. It happened a couple of times on my first ride and I put it down to not being properly in gear when cranking. But now I'm thinking it could be this? Is yours creaking all the time? Mine isn't. It's happened twice I think, but sounded quite severe. I even stopped to see if something was broken the second time, but everything seemed fine and it didn't do it again afterward so I was none the wiser.
Its was doing every pedal stroke.. I took it apart and gave it plenty of grease but couldn't really get into any clutch mechanism that was obvious… Its now on and off creaking so maybe needs some more tweaking!!
Maybe it's something else with mine then. Perhaps it was just slightly out of gear when I cranked it then. Think I'll check the adj, of the mech as it occasionally seems to slightly over-shift when downshifting.
Sram Tech gave me this reply when I asked:
[i]The clutch on the derailleur does require some breakaway force. This is normal. In some cases, with some frame designs/gear ratios/setups this breakaway will be more noticeable than others. This does not mean that there is nothing wrong with your particular derailleur.[/i]
?? Mine seems to have improved but only time and a few more rides will tell!! To top off snapped a tooth off my cassette which has gone back to Sram
only thing that puts me off 1x11 is the cost of a replacement cassette. however, given that x1 is out now, and starting to appear on more and more bikes, i imagine the price will start falling
I think I've said it about 50 times on various threads now, but it's not expensive because it's 11 speed, or because it's new or anything else. It's the construction. Similar 9 and 10 speed cassettes are comparable prices, and haven't changed in the 5 years they've been on sale. SRAM may reduce the cost of cassettes, but I wouldn't bank on it, until they make one in a more 'conventional' way.
What about the 40t or 42t adapters that are knocking around? They will fit to SLX or XT 10 spd cassettes. General lee is the name of one - can't remeber the other.
like the new X1
Getting there certainly. Almost down to XTR pricing!
There are loads of them now. You still don't get the range of 11 speed, but yes a cheaper alternative for sure.
