Fox 36 talas rc2, blue talas knob won't move, well it has a few mm movement but won't turn to lower the fork.
I've not used the talas in a fair bit, could it be just very stiff?
What I did notice is the blue dial has a dent in it, I've removed it and straightened it so that's not affecting it!
Maybe dirt and water ingress into the upper adjuster assm, it'll seize the ball bearings and can jam some other bits in there.
Cheers, won't do any harm riding away at it? Never use it anyway.
Ps - do you sell foam rings on their own? Need some for the revelations on the hard tail.
No shouldn't do, however if there's dirt in the system it maybe wearing seals so could cause issue in the future.
Yes we can supply foam ring separtley, however there is a minimum order price of £10 due to card charges.
Cheers, ill keep doing the lower service over the summer and maybe get them over to you for a full service after a few planned trips in the autum.
