how do i do it.
big allen key to take cranks off, what about getting bearings and gubbins out.
i am gonna fit a fsa steel threaded sleeve to run shimano.
Drift them out and remove the circlips that lurk behind them
Screwdriver, hammer, circlip pliers optional but preferable. Small hammer and an old bearing to fit the new one.
Mine never had circlips i just used a screwdriver and a hammer
Ton, you can use one of these ebay item 391083852436
firestarter - Member
Mine never had circlips i just used a screwdriver and a hammerPOSTED 21 MINUTES AGO # REPORT-POST
Yours was a Pressfit 30 not BB 30 in that case .
Not necessarily. Not all BB30 frames use circlips.
Fsa do a removal tool for a few quid, not worth drifting out with screwdrivers and hammer imo
I just used a 10mm dia metal drift to tap mine out last week and used a BB30 press in adaptors and my head set press this week.
Maybe worth refitting the bb30 bearings or fitting some new ones blather in grease including the circlips if your trying to get rid of some noise.
Now I'm used to this design I prefer it Shimano, granted Shimano cranksets are better though.
Crag - MemberFsa do a removal tool for a few quid, not worth drifting out with screwdrivers and hammer imo
Though mine was PF30 I imagine it ain that different, I had to use a drift (ok not a screwdriver), as the FSA thingy was next to useless on the 'tight' side
if the bearing feeling notchy in the frame but ok/smooth out of the frame,
I would get the frame reamed.
the bike is new, fitted with a single front ring.
i want to run a double upfront and have a new shimano double to fit.
