I'm reading good things, but anyone care to share real life exp?
Also, is the flow together with the upgrade kit exactly the same as the I Flow from a VR perspective? If so should I consider that option as it means I can use it as a stand alone machine without having to always plug it into the tv?
I have the Flow 2200 with TTS but opted against the VR kit. TTS is great as you can create and save routes using Google Earth as well as buy loads of route DVDs etc.
TTS tracks and style all your data. You can also create and edit training sessions that focus on anything you like eg intervals whereby you set the wattage accordingly every X seconds blah blah. All in all you have loads of control.
Look at my post history if you want to see more stuff I've written about it on other TT threads.
