Syntace 12 X 142
[Closed] Syntace 12 X 142
[#2420828]
Anyone got a bike (or experience) with the [url= http://www.syntace.com/index.cfm?pid=1&pk=1314 ]Syntace X12[/url] system?
how easy is to use? How does it compare with Maxle?
Posted : 31/01/2011 8:33 am
its the easiest system in the world
Posted : 31/01/2011 9:14 am
yep I have, it's essentially the same as maxle, but the extra 7mm is a 3.5mm slot in each rear dropout, which the wheel slots into. it's how maxle should have been designed originally.
Posted : 31/01/2011 10:39 am
cheers.
I've got Maxle-Lite on my Thors, and that has slots for the wheel to slot into. Sounds like a great design. Thanks.
Posted : 31/01/2011 10:55 am
? oh, I thought maxle frames didn't have any slots for the wheel. I thought you had to sort of hold the wheel and frame in alignment and then push the maxle axle thing thru.
Posted : 31/01/2011 11:02 am
Don't know about the frames, I've only got it on a pair of forks.
Posted : 31/01/2011 12:29 pm
I have 135 x 12 on my Nicolai - and holding the rear wheel in place with the chain tugging it forward while threading the maxle/bolt through is a pain in the rectum. The 142 x 12 has lips in the dropout which supports the wheel in place so you don't have to. As above - it's how the 135 x 12 should have been done.
Posted : 31/01/2011 2:01 pm
Yes
Very easy
Better than Maxle imo - little to go wrong
Posted : 31/01/2011 2:04 pm
Can you convert a 135 Hope Pro 2 to 142 syntace?
Posted : 02/12/2011 11:05 pm
Yes, the conversion kit is approx £20 I think. I did the Pro2 conversion a few months ago for my Cube Stereo frame. Mine was a standard QR to 12mm X 142mm Syntace/X-12 swap, but the Pro2 is def convertible.
Posted : 02/12/2011 11:44 pm
