Switching from a 1x...
[Closed] Switching from a 1x9 to a 2x10.
[#5609151]
Right guys!
I'm thinking about changing my current mountain bike gear set from a 1x9 to a 2x10. Maybe even a 2x9 if possible. I'm new to the mountain bike scene and I feel like I'm loosing to much energy racing up hills in high gears which means I get knackered easily. Whats the best way to change it? Can I keep the rear cassettes and mech (all XT) or even the chain and buy the two front cassettes and the gear shifter? Or is it better to buy a whole new set? Prefer to keep XT for reliability reasons. Any help would be appreciated 🙂 Cheers!
Posted : 16/10/2013 8:34 pm
Yes for about £90 your LBS should be able to shove a Deore double cranckset including the bottom bracket at the front. XT shifter is c. £40. Keep the back as it is for now! Sorted!
Posted : 16/10/2013 8:40 pm
Can't give you a recommendation specific to your question about the compatibility between cassette and rings/shift mechs, but think tomkerton is right. As far as use, my change was a little different from a 3X9 (XTR)on my old bike to a 2X10 (XT) on my new bike. It did take a little getting used to, but after a dozen or so rides, really like the 2X10. Give you a lot of good gear combinations without a lot of overlap and it won't cross chain (of course that wasn't issue with your 1X9 setup).
Posted : 16/10/2013 8:49 pm
Awesome, Cheers guys! I'll let you know how I get on... If I manage it.
Posted : 17/10/2013 10:18 pm
Good luck. I did the similar to busydog, went from the supplied SRAM 3x8 to Shimano SLX 2x9. Good range, More straightforward to maintain, and lighter i suppose too.
Yours is a good plan, 2 up front works well for general trail riding IMHO
Posted : 17/10/2013 10:38 pm
Fantastic invention those front mech's aren't they 😉
Posted : 18/10/2013 8:17 am
