Keep meaning to get one. Would the Lizard Skinz Swingarm one fit, as all the pictures I've seen look like it's got a split in it that's specific to a certain (American) frame?
innertube?
one of these might do the trick.
http://www.chainreactioncycles.com/Models.aspx?ModelID=18095
cut up an old tyre and zip tie a narrow strip of the tyre to the underside of the drive side swingarm. A mate has done this to his A160 and it's quietened it no end.
I used this on mine http://www.biketart.com/products/framewrap , not pretty but does a good job.
On my five , I just helicopter taped the underside of the swingarm.
I use self adhesive velcro (the furry side) along the bottom, works a treat and stops noise too.
Just zip tie inner tubes to it.
Did that on both sides on of my 5, protects the big swing arm sides from scuffs and makes it abit quieter too.
Looks crap but it's a bike!
just a bit of helicopter tape under the swingarm sorts any chain slap, a lizard skinz or inner tube looks terrible imo
Ok, what's Helicopter Tape then?
Got a lizard skin on mine - but that only covers the lower part of the swing arm - but then that is the bit that gets mullered by the chain.....
Is that a standard Lizard Skin?
No - it's a tidgy one. I don't know what sizes they come in but it'd fit around a hartails standard tubed rear triangle.
Works fine and keeps the chain off the frame.
The upper part of the rear triangle is still exposed - but little hits it....
Good idea.
Ohhhhhhh. @rsew**k. 😆
