Swapping Shimano mt...
Swapping Shimano mtb callipers/levers
[#12820566]
I suspect a leaky calliper* on the rear and have a spare front that could be swapped in. Is it just a matter of unbolting and bolting up again or should I replace banjo/olive/etc (at calliper end)?
*yes the one i was adamant was fixed (for about 3 weeks) after replacing pads and rotor and cleaning calliper.
And should I end up swapping levers (so things match later down the line) do you always replace the old olive and insert thing? Is cutting the hose shorter the only way?
Posted : 13/05/2023 10:11 am
I'd normally just replace the olive by crushing it with some pliers. Never had any issues doing it that way.
Posted : 13/05/2023 10:45 am
 PJay
There won't be an olive and insert at the calliper end if it's a banjo fitting. A couple of things to bear in mind is that there should be two tiny rubber O rings, one either side of the banjo, don't lose those and if you're replacing like for like the existing banjo bolt should be okay if you don't have a replacement. However there are significantly different lengths of banjo bolt depending on which side of the calliper it's fitted.
Posted : 13/05/2023 10:57 am
If it's a banjo caliper then can't you just unbolt / replace / bolt?
If it's direct line into the caliper then it will be olive and barb. You should replace the crushed olive with a new one but can reuse the barb (also the case for the lever).
Posted : 13/05/2023 10:58 am
Cheers all.
Posted : 13/05/2023 11:05 am
