Swapping hoses on H...
[Closed] Swapping hoses on Hopes
[#4411304]
Need to swap and shorten the hoses from left to right (and vice versa). Will this work on a set of mono mini's? Thanks.
Posted : 29/09/2012 12:41 pm
Few quick points
Brake Fluid is cheap (from a car supplier)
Bleeding Hope Bakes is easy
How much excess do you have? If not much then route to avoid cutting. Maybe worth getting a end kit on sale or return from a LBS.
If you can route fine the just swap and rebleed.
Posted : 29/09/2012 12:47 pm
