Suspension fluid
[Closed] Suspension fluid
[#2867483]
I've accidently used 7.5wt instead of 10wt in my Fox Floats. Does anybody know whether this would make any difference? And if so... and so?
Dave.
Posted : 19/06/2011 8:58 pm
 nuke
IIRC Fox don't do 7.5wt anymore and you use 10wt instead. Been using it with my forks and can't say I noticed a difference
Posted : 19/06/2011 9:03 pm
slightly less damping. depending on the adjustments you've got you'll probably be able to adjust your settings slightly to compensate
Posted : 19/06/2011 9:05 pm
Depends which make of 7.5wt and which make of 10wt. It's not a standardised measurement, so lots of latitude between manufactures. See [url= http://www.pvdwiki.com/index.php?title=Suspension_Fluid ]this.[/url]
Posted : 19/06/2011 9:10 pm
I used shell synthetic 10wt but going back to 7.5 as the rebound is either on or off with the 10wt. So I'm going to try rock oil 7.5 and see how that goes.
Posted : 19/06/2011 9:32 pm
 LoCo
As Tucker says viscosity varies between different manufacturers oils, 7.5 is fine up to about 13.5/14 stone riders as a rough guide.
Posted : 19/06/2011 10:00 pm
Fox have 2 different types of 10wt oil, as far as I can see the Green 10wt is basically a 7wt oil as this is the 1 you use if your fork should/used to take a 7wt oil. so don't worry about it I reckon!
Posted : 19/06/2011 10:04 pm
