Superstar XCR Chain...
[Closed] Superstar XCR Chain Device HELP!!!!
[#3573192]
[url= http://www.flickr.com/photos/74537358@N04/6713263973/in/photostream ]XCR Pic[/url]
Ok i have a Shimano Octalink 68mm BB.
When i put the XCR Device on, well urm things don't line up!
Please any advice?
Posted : 17/01/2012 8:54 am
You may find the chain line is optimized for hollow tech 2 chain lines. I have found using current SRAM cranks with either 2 by ten spiders in 104 or spider less cranks I.e what home brew componets can make you I have had to use the pauls chain device which has a lot of range in it's chain line adjustment. Can you space the top guide at all outboard a bit to make it fit.
Posted : 17/01/2012 9:09 am
That's what I found when fitting with my isis bracket. I used a washer from an old set of v-brakes (approx 2mm) between the upright and the guide. The washer had a rounded surface which let the guide be angled slightly along the chain line.
Posted : 17/01/2012 9:17 am
Hi Guys,
Cheers. You have mentioned exactly what i thought i may have to do. Space out the Guide from the plate.
Nothings ever simple, but cheers. I don't want to but another Crankset and BB just to fit this thing, so i'll fabricate something tonight.
Posted : 17/01/2012 9:20 am
