Superstar Plasma Ch...
[Closed] Superstar Plasma Chainguide
[#2322991]
Morning all,
Tried phoning superstar but no answer so hopefully someone here will know.
Put the freebie plasma guide onto my five yesterday but it rubs and needs some more washers installing. Does anyone know what size washer/screw they take so i can pop to b&q on the way home? It must be standard for the ISCG mount but i'm loathe to fork out for the e13 screw and washer pack to get it to fit.
Cheers in advance
Posted : 30/12/2010 10:53 am
 DT78
Don't know about the superstar guide, but for the guides I have fitted I've always used spare shims I have lying around left over from fitting brakes. At a guess I'd say they are m4? Take a bolt with you into B&Q?
Posted : 30/12/2010 11:00 am
Thanks. No shims lying around unfortunately as i've got formulas which use the brake and clamp method.
Posted : 30/12/2010 11:04 am
not much help but is this freebie from a dirt subscription as im still waitin for mine
Posted : 30/12/2010 11:11 am
Yeah, thats the one. Have you been phoned by superstar to confirm whether you want ISCG etc? If not then give them a ring as they'll be waiting for that info before sending it out. If you've got a five you may want to ask for a few more washers as well 😀
Posted : 30/12/2010 11:24 am
 rlt
For the Dirt freebie you should have received an email asking you to confirm whether you needed ISCG/ISCG05, colour etc. They were all supposed to be sent out at the same time.
Posted : 30/12/2010 12:41 pm
Yeah rit i replied to the email, have you go yours?
Posted : 30/12/2010 1:29 pm
Obviously yes 🙄 It was sent out early december.
Posted : 30/12/2010 1:53 pm
