Anyone bought the kit and done it, i cant seem to find any info on the process, ive stripped mine as the bearing collapsed and cant seem to get the bushing and bearings out.
Posted : 21/11/2015 5:20 pm
Email them, they sent me instructions. Same as other pedals so google nukeproof service.
Bearings you can just drift out but the bushings are a pain as there is a lip which prevents you getting access. I found a bolt that had just the right diameter head and used that. You may also be able to use a bmx pedal axle as the crank thread diameter will let you screw into the bushing.
Posted : 21/11/2015 5:32 pm
