Superstar hubs. .re...
[Closed] Superstar hubs. .replacement bearings...where? which?
[#5221506]
As above, not wanting to spend millions on them but want decent/ ish ones.
Anybody replaced theirs or should I take them to the LBS?
Thanks
Posted : 05/06/2013 9:40 pm
I've got hope bearings in mine, £4 a pop from wiggle on offer. I'd steer clear of cheapo bearings.
LBS did mine, I couldn't get the old ones out!
Posted : 05/06/2013 9:53 pm
Interested in this too, front bearings for a switch hub. Which bearings did you buy?
Posted : 05/06/2013 10:04 pm
front bearings are 6804 in the switch. I have a pdf somewhere of all the different hub bearing numbers.
Posted : 05/06/2013 11:02 pm
easy enough to replace just make sure you dont pinch the bearings too tight on the central spacer as it will affect smoothness and bearing life.
if its a rear and your doing the freehub, i found it best to use a vice rather than a hammer, as they are prone to cracking.
i made the error of getting cheapo "5 bearings for £5" ebay jobsworth, but lasted 2 days in scotland! got SKF and were much better
Posted : 05/06/2013 11:13 pm
kaytec good bearings great guy 😀
Posted : 05/06/2013 11:36 pm
I have play in the front wheel, the rear is the same age but has no play. Should i change the the rear bearings aswell anyway?
Posted : 06/06/2013 10:16 pm
New bearings? I suggest these:
Posted : 06/06/2013 10:18 pm
Where would one get them from and is it a diy job?
Posted : 06/06/2013 11:19 pm
