Superstar Floating ...
[Closed] Superstar Floating Rotors: Any Good?
[#2667527]
I'm looking for some rotors to go with my Hope Mono M4's and I'm wondering if the Superstar Component ones will be suitable. Has anyone used this combination? Thanks.
Posted : 16/04/2011 1:03 pm
i fancy the green ones but was also thinking along the same lines
Posted : 16/04/2011 1:53 pm
I want some red ones, or maybe some white ones.
Posted : 16/04/2011 2:09 pm
Does anyone use these rotors with Hope brakes?
Posted : 16/04/2011 7:16 pm
Think they were only available this week so might be a little too early.
Posted : 16/04/2011 8:02 pm
[url= http://www.wiggle.co.uk/hope-floating-saw-rotor/?utm_source=google&utm_medium=base&utm_campaign=products ]real ones[/url]
Only £5 cheaper than original hopes on the 180's
Posted : 16/04/2011 9:03 pm
Which m4s? The split caliper ones were 165, 185 or 205 with a pretty thin braking track. It might not be a great fit.
Posted : 16/04/2011 9:06 pm
I'm not sure. There is what looks like a manufacturing date by the logo on the side of the caliper of 01/04. A pin goes through two holes half way along the pads to hold them in the caliper.
I'm pretty sure these brakes are designed for 160mm rear and 180mm front. My juicy 3 rotors are 160mm rear which seems to fit but my front rotor which I'm pretty sure is 185mm is too big. I think I just need to get 180mm and 160mm rotors that are suitable for these brakes.
Posted : 17/04/2011 11:44 am
