Superstar Brake Ada...
[Closed] Superstar Brake Adaptors
[#3652346]
Ordered a type 3 brake adapter from SS which arrived today. Type 3 was supposed to be Front PM-IS 180mm
Got a note with delivery saying that there were no more type 3 adaptors in stock and they supplied me a type 2 (Rear PM-IS 160mm) instead and that it is exactly the same shape for my setup.
Happy to give it a bash, but am I going to encounter problems at all?
Posted : 07/02/2012 12:37 pm
they're essentially the same.
most mounts that fit on the front, fit on the rear with 20mm less disc size.
Posted : 07/02/2012 12:40 pm
 cp
as greeble
Posted : 07/02/2012 1:07 pm
Nice one chaps, I will give it a go this evening. Also My front disk is a hope floating rotor, will I need a few washers to get the extra 3mm needed for the disk?
cheers
Posted : 07/02/2012 1:15 pm
extra 3mm? I don't quiet understand. the disc thickness is the same.
Posted : 07/02/2012 1:17 pm
Hope rotors are meant to be 183mm diameter?
Posted : 07/02/2012 1:18 pm
ah you mean you want an extra 1.5mm....
yes a washer between the caliper and the mount should do it
Posted : 07/02/2012 1:19 pm
Thanks greeble
Posted : 07/02/2012 1:28 pm
