super glue instead ...
[Closed] super glue instead of loctite - will I die?
That link for syntace is nothing todo with bolt torque or thread locking compounds
Never ever put that assembly paste stuff on a thread
Posted : 20/03/2013 8:16 am
Read the bit at the bottom, orangeboy
Posted : 20/03/2013 9:05 am
Can open... Worms everywhere...
Posted : 20/03/2013 9:33 am
I grease those bolts and nip them up by hand without a torque wrench. They've never come loose in all the time I've had HT-2 cranks, so maybe 4 or 5 years. You'll be fine without threadlock or superglue. The only things I'd threadlock on a bike would be the fasteners holding the suspension pivots together.
Ex bike mechanic FWIW, and 15 years designing equipment for the oil industry 😉
Posted : 20/03/2013 9:57 am
i wipe all the bolts i use on my cock before fitting and as he is such a big fella i can wipe loads of bolts up and down his huge size. You should try that, but your cock won't be as big as mine.
i find the feathers get in to the threads really well.
Posted : 20/03/2013 10:13 am
So doing everything up so it's just short of 'stripped' on my torque wrench is a bad idea?
Should I be aiming for Real Tight in future?
Posted : 20/03/2013 10:19 am
Just do it up until it strips, then back it off quarter of a turn. Job done 🙂
Posted : 20/03/2013 10:45 am
+1 Stop just short of stripped is perfect 😀
Posted : 20/03/2013 10:47 am
(I need to find who makes that grease as it is very good).
Err... Shimano. It is good, not cheap, but I've had a tube for a couple of years! Comes in a workshop tub if you go through lots. About £50 though.
Posted : 20/03/2013 10:51 am
There's a lot of people on this thread claiming to e engineers, but how many are [i]proper[/i] engineers with their own parking space ? That's what I want to know.
Posted : 20/03/2013 11:04 am
I notice the sign saying 'Software' immediately above has been removed.
Posted : 20/03/2013 11:05 am
It did say "light" on the removed sign, but due to events yesterday he's been downgraded.
Posted : 20/03/2013 11:20 am
[i]It did say "light" on the removed sign, but due to events yesterday he's been downgraded. [/i]
"MTG - Prince of Darkness"
Posted : 20/03/2013 11:21 am
In what alternative reality would a Software engineer get their own parking place?
Posted : 20/03/2013 11:24 am
[i]Yes, you will die. Even loctite won't prevent that.[/i]
Precisely, so perhaps its not an issue of whether the OP will die.
But rather, who will be to blame ?
Posted : 20/03/2013 11:26 am
Thread lock is only useful if you haven't torque your bolts up properly.
I'm definitely dropping that into an email to the Head of Clanky Engineering today.
Speshpaul - Member
One I hope to never visit *shudders*
Posted : 20/03/2013 11:34 am
The way this post is degrading, thread lock is likely to happen shortly..... 😆
Posted : 20/03/2013 11:48 am
 sv
Grammar engineer to this thread please...
Oh sorry !.
Posted : 20/03/2013 11:58 am
I follow a strict routine when replacing bolts that ensures consistent tightening of threaded fasteners.
I wipe the offending article on my shorts, maybe add a bit of spit to penetrate the filth, dip it in a pot of contaminated grease, swirl the grease over the thread with a finger then tighten back up until my knuckles turn from red to a little bit white, or until the allen hole has rounded off so no more torque can be applied.
Posted : 20/03/2013 12:17 pm
Opps teach me read the whole page
Posted : 20/03/2013 1:00 pm
Just use half the number of bolts and twice the torque, saves it coming undone...
Posted : 20/03/2013 1:03 pm
 IA
Do it up however you like, if it falls out use threadlock next time?*
*may not be the safest approach, but is realistic 😉
Posted : 20/03/2013 1:11 pm
 Del
Wookie Spaff. accept no substitutes.
Posted : 20/03/2013 1:13 pm
Posted : 20/03/2013 2:06 pm
[i]Wookie Spaff[/i]
Posted : 20/03/2013 2:12 pm
For gods sake - just man-up and tighten the damn bolts! - Your fist is the ultimate torqe wrench - just watch out for them darn Fox 36 pinch bolts. Safe torque for these is tighten 3 turns then back off 4 - remove - throw in the bin and buy something else.
Nick - Bronze Swimming Certificate
Posted : 20/03/2013 2:52 pm
Page 2 / 2
