Suntour Raidon Fork...
[Closed] Suntour Raidon Forks
 Tim
[#11990495]
Ive had the neighbours nippers bike in the shed as a roll pin in the air spring had snapped and they had overextended as a result. Easy fix and caused by poor tolerance as far as I can tell.
However, the damper appears to do nothing. From what I can tell it's a sealed unit and designed just to be lightly greased.
Does anyone know if there is anything that can be done with the damper to ressurect it?
Tim
Posted : 07/08/2021 12:34 pm
Not servicable.
https://www.srsuntour.us/products/raidon-lo-r-cartridge
Posted : 07/08/2021 12:44 pm
 Tim
thols2
Not servicable.> https://www.srsuntour.us/products/raidon-lo-r-cartridge
I feared as much.
Although, they aren't overtly fast rebound, and I doubt they had much in the way of sensible compression damping in the first place.
Posted : 07/08/2021 12:53 pm
Is it a 26er fork? I have an old Epicon fork that are destined for the tip. The forks do work, the hole where the axle fits has elongated.
I tried to get the thing bored out and sleeved but it moved in the machine. You are welcome to it if it does the job.
Posted : 07/08/2021 6:52 pm
 Tim
27.5, but the damper may be the same.
Thanks for the offer but I wouldn't worry as the kid doesn't seem to care
Posted : 08/08/2021 11:44 am
I have an 26" Epicon(IIRC) with damping that isn't working properly. It failed so I stripped the fork and pulled the damper apart, it seemed to be an open bath but sealed cartridge. I wonder whether it would be like the one linked above. I couldn't find anything about service online but I don't want to get rid of them as they're a really nicely made fork with virtually everything made of cnc'd aluminium
Posted : 08/08/2021 11:55 am
